Globe Motor Spec Sheet
Ok ... I searched. And searched. And searched some more.
I cannot seem to find a spec sheet (drawings of the motor, speed/torque curves, etc.) for the globe motor. Anyone have one lying around? I know I had one last year ... I just can't seem to find it. Help would be greatly appreciated!- Katie |
I'm looking for a drawing of it too. Thanks, though.
- Katie |
Humn... I've designed a few systems this year using numbers taken from the Inventor models of the kit made by Autodesk. I think this is FIRST's substitute for the drawings this year, and I can't say I wholly like it. I'm having trouble trusting Autodesk for demensions of critical systems in the bot, but I've tried to verify some numbers with a caliper, and I haven't found a mistake yet. Perhaps when everything is built, and it all fits together, we can get used to trusting Autodesk in the future. Still, if you use numbers off the model, I'd sugget checking a few easy ones yourself.
Anyways, I pulled some numbers from the Autodesk model and put them in the attached picture. You can get the model here: https://folders.buzzsaw.com/2003FRC/...20files?Public , and it's called grm_motor.zip . You can then pull other numbers off of it yourself... Last edited by Suneet : 21-01-2003 at 21:41. |
| sheet rubber | Adams High Man | OCCRA | 1 | 20-10-2002 10:07 |
| Globe Motor | archiver | 2000 | 4 | 24-06-2002 00:15 |
| Globe Motor | archiver | 2000 | 0 | 24-06-2002 00:15 |
| So you want to stall a Globe Motor... | archiver | 2000 | 1 | 24-06-2002 00:09 |
| Globe Motors & other FIRST Suppliers at Design Show | archiver | 1999 | 2 | 23-06-2002 22:07 |
