Go to Post My first instinct was inflatable clowns and 5 of them beating on the robots at all times, but then I thought, thats probably not right. - Dan Richardson [more]
Unread 22-01-2003, 10:07
esellers's Avatar
esellers esellers is offline
#1201 (CSI: Monroe)
esellers is an unknown quantity at this point
reflective tape
Would it be better to order the special reflective tape from MMH? Or, do you think using some bought from Home Depot is good enough?
Unread 22-01-2003, 11:36
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
make sure its retroreflective and not just regular reflective tape...cuz the retro reflective tape has special properties making it ideal for sensing situations.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 22-01-2003, 12:46
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Having the retroreflective tape is very important. Regular reflective tape won't work, because it doesn't return light directly to its source. Without that, the optical sensors won't work well at all.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 22-01-2003, 13:51
crazycliffy crazycliffy is offline
crazycliffy is an unknown quantity at this point
actually it depends on your application,
for line tracking it is ok to use regular white tape.
upto like 8" or so and it can still detect the line.
But for greater distances > 216" (6meters),
gotta use retroflective tape. (e.g. scouting for stacks)
Unread 22-01-2003, 15:29
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
As far as I know, the white line on the ground isn't even "reflective", it is just white tape.
The boxes have the retroreflective stuff on them.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 22-01-2003, 16:02
Actually white tape is reflective to a certain degree.
you can believe me, as I've already made our robot's
sensors.
i've tested it on black surface, carpet, and if i put
a peice of tape (white), the sensors become "active"
Unread 22-01-2003, 16:20
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
sensors.
Isnt that because the sensors see the change between white and black? I'm told thats what happens by our electronics people... but im not a programmer, so feel free to ignore my ignorance
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 22-01-2003, 16:24
esellers's Avatar
#1201 (CSI: Monroe)
We did get some reflective tape from the bus shop called 3M Scotchlite Reflective Material Stripe that I think will work. I'm looking for it on 3M's site now for any specs.
Unread 22-01-2003, 19:10
Rookie Year: 2000
the difference between retroreflective tape and regular reflective tape if i can remeber my physics class...has to do with the fact as stated above the retro tape will reflect it back at a 90 degree angle from the source no matter what angle u strike it at...i think i said that right...basicly if u hit it at 45degree's it'll bounce right back into the sensor just like if light strikes it perpindicularly.
Regular reflective tape just has properties similar to a reflective surface and i believe it probably either diffuses the light a bit or polarizes it...dont know for sure as this is not my area of expertise.
All i know is they wont work the same..
Josh
reflective tape Cpt S.T.U.C Rules/Strategy 9 05-02-2003 07:43
Reflective tape on boxes S2Taz General Forum 1 20-01-2003 17:24
How is reflective tape applied to HP crates? Dr.Bot General Forum 2 06-01-2003 15:17
Substitutes for reflective tape? Oakridege_665 Technical Discussion 1 23-01-2002 11:44
Reflective tape in the kit. Anton Abaya Technical Discussion 13 11-01-2002 14:16
