The numbers on the side adjust the speed. It's not that big of a change but it does get faster and slower. One thing you could do though is create a gearbox to shift gears from low speed to high speed.
Re: Re: Re: Programing
If you're referring to some other numbers, I'm sorry. Could you please explain as I would be quite interested. --Rob |
well first lets wait and see if we actually get it to work this eyar before we actually say anything. Once we get its on our robot and working we can brag then! Cipher X |
Not to bring this up, as i hardly post, but this caught my attention:
Yeah, but the guy was talking about using software control on the drill motors in high gear... major loss of torque there. |
We used the programmatic shifting last year, and while you can get a bit of control from the lower speed, it doesn't do anything for your pulling power.
Because the drill motor gear boxes don't like to shift under load, we lock them in low and use a set of spur gears on a slider to shift. Not original, but it works very reliably. This year we're using both the CIM and the drill motors in low. I think we will just push the whole ramp to our goal zone.... Good Luck.
#10
There are two real ways to shift, 1) Shift the planetary system in the gearbox of the drill motor. 2) Shift actual gears in your gearbox after the motor. Having X ratio and giving it 50% power will not give you more pushing force, it will only slow your speed. The advantage to limiting power is less draw on the battery, and less chance of overheating your motor. You will NOT gain tourque by supplying less power. If you look at the power curve for the motors, they are all in accordance to 12 volts being delivered. You can, for the most part, just shift everything down by about 1/2 to see what your speed and torque would be at 50% power. If you change gears however, you'll shift the curve to the left or right. --- On the topic at hand.. There are 2 good ways to go about shifting. 1) Servo motor - Turn the servo and it worms the shifter over to a new position. Doesn't take much torque to slide, and the servo doesn't provide much torque.. beatiful combination, rather imple to make with a pretty wide tolerance. 2) Small Pneumatic cylinder a) above each motor's shifter you can mount a small cylinder that is attached directly to the slider. Pneumatic extends, motor shifts. Program in to not allow motor to be moving to fast when shifting or a nice grinding sound might be heard. And grinding is never a good sound. b) If the motor's are in line with eachother, you can have a single cylinder mounted above them both. When it extends, it pulls both pins, shifting both motors. You'll have to engineer a bit more with this one so that they both shift to the same gear. If the motors are facing oppisite directions and get the same linear force, they will shift into oppisite gears. (One low, one high). There are ways around this, such as flipping one motor around (which hurts on space) or a reverse pusher. (Reverses force on another bar to change force and shift gears in oppisite directions and same gear.) c) Within each gearbox, after the motor, have a cylinder actuate a shaft of gears into another position. This works on the same concept as a car's transmission. When cylinder is retracted, gear "a" is being rotated by gear "b". When cylinder is extended, gear "c" is being rotated by gead "d". a and c would be on the same shaft, and gears b and d would be on the same shaft. I don't have any diagrams to show this, but if you hunt around you'll find it. d) (I saw this in 469's gearbox last year and thought it was a very neat idea). Have the gearboxes in the same orientation as eachother, but the shifting gear (a, c above) be oriented differently. When the cylinder extends, it pushes a and c's shaft to interact c to d. mount a shaft to extend with the cylinder so they both get actuated. If you need more information I can draw up a diagram or contact team 469 about how they did this. |
#11
Can someone tell me which position is high speed and which position is low speed?
#12
With regard to locking the gear on the drill motors: We used a ring of PVC to lock it in, but found that after a while the ring would tend to disintegrate, but the problem would not be noticed till we got a jolt and the motor shifts to nuetral (usually under full power!). So, the locking works, but its a good idea to a) make sure your lock is stable and b) make sure you can get to your motors easily. Just getting the point where wer could bring a screwdriver to bear on those motor mounts required 1/2 hour of work!
#14
multi-seed trannys
Don't get too carried away with the technology. It all depends on the game rules and the course. Form follows function, and all of that...
Last year. we had a slow, but extremely reliable robot as far as the drivetrain was concerned. No spares, no adjustments, no breakers popping, no hassle. There were enough other things to worry about... |
| gear shifting | Stephen Kowski | Motors | 19 | 30-03-2003 21:33 |
| Segway-like device being developed by Honda | MattK | Dean Kamen's Inventions | 17 | 23-11-2002 15:31 |
| RoboStars 'Mini-Arm' Control Device | archiver | 2000 | 5 | 23-06-2002 22:28 |
| Best Ball Collecting device of 2002 | D.J. Fluck | General Forum | 32 | 07-05-2002 19:15 |
| Like Device | sasquatch | General Forum | 6 | 31-01-2002 08:51 |
