Go to Post The events are not just a competition, but a celebration of 6 weeks of hard work. - ChristinaR [more]
Unread 22-01-2003, 19:19
mickjagger mickjagger is offline
mickjagger is an unknown quantity at this point
omniwheels on steel mesh
Looking at the omniwheel designs from last year they seem to be a great idea to replace castors! But has anyone with an omniwheel robot from last year tested them out on the steel mesh? Wouldn't want to put all kinds of work into making one and then find out that it stinks on the mesh. Thanks!
Unread 22-01-2003, 20:19
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
OmniBot
Our team had an idea for a omnibot last year and it worket real well, Yes my voice is foaming with sarcasm
Unread 22-01-2003, 21:35
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Our robot's omniwheels (6" diam) last year (pic uploaded below) were awesoem on carpeting but are not good on steel as they've got aluminum and lexan
Our 9" omniwheels this year came in today. Though not as pleasing to the eye as last year's, they're lighter and the treads are made of a very sticky urethane that can go up the mesh easily with our two other 9" wheels which aren't omnis.
Name:	omni wheels.jpg
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 22-01-2003, 21:37
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
why not just make your own wheels? i don't see any point to using those omni wheel things, and not to metion that they are illegal this year anyway, they have metal touching the carpet thats a big no no this year
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 22-01-2003, 21:39
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
If you read my post carefully, you'll notice that I said it worked great on carpet but not on steel... and that this year's new ones have URETHANE treads which are basically sticky hard rubber. They are perfectly legal... the great advantage to omni wheels is that they allow you to turn around one point without having your wheels skip... which sucks because that could result in your stack falling down if it not braced. The idea to use them came to our team from Cornell's robocup team.
Also, we did 'make' them. The pic above was something we designed in Inventor and had the Borg Warner guys look at. They then machined them for us with our specifications. We did the same this year for the new 9" wheels... you can't buy these at the quality we have them commercially.
Unread 22-01-2003, 21:42
Roboticsrob
having traction also works for that
Unread 22-01-2003, 22:15
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
Actually, it doesn't.
When I refer to moving around one point, imagine having a tank drive train... hence, moving forward with one joystick would pivot it around one point. If you had wheels with lots of traction, it'd stick to the floor material well and when turning, would skip up and down causing the robot to shake... hence, smoother wheels would be better for turning around a point. However, when considering gameplay, that's a lack of traction which results in you getting pulled/pushed. Omniwheels offer traction in one axis and rotation in another which allows you to turn smoothly. Using a pair of omniwheels in front and a powerful pair of high traction wheels in the back allows you to get the greatest traction while being able to turn perfectly smoothly.
Unread 22-01-2003, 22:56
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
the omni wheels are legal as long as the wheelie things dont go through the mesh...at least i think so... cause it is a little late to find this out...
bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 25-01-2003, 19:21
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
bad
I do believe most Omni-Wheels would now be considered illegal. (even if they didn't go throught the mesh) I've only seen a few that didn't have metal or hard plastic contact the carpet.
Unread 25-01-2003, 19:27
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Omni wheels in general are NOT illegal. Only those that have metal touching the surface are illegal. You mush consider, however, ways to avoid going through the mesh.
Unread 25-01-2003, 19:32
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
It's pretty simple to make it not go through the mesh. If you look at the pic of wheels last year, it'd be impossible to fall through something. This year's current model is roughly the same thing.
Unread 26-01-2003, 09:13
Jim Meyer's Avatar
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
M17 - Traction devices may not have surface features such as metal or hard plastic studs, cleats or other attachments.
I interpreted this as not allowing the normal "hard plastic" side rollers, which serve the same function as cleats. Has there been an update on the forums that I have not seen?
Unread 26-01-2003, 09:33
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
just as long as you don' screw up the carpet it'll be fine
Where has all the fun gone?
Unread 26-01-2003, 20:35
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
Seems to me that you'd be better off investing in a short 4 wheel drive assembly in the rear and casters up front. Like a tractor-trailer cab
. Other than when entering an incline, you'd have 4 wheels driving. Scrub steering shouldn't be much of a problem if the wheelbase is extremely short.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
  #15   Spotlight this post!
Unread 26-01-2003, 22:45
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
I would be really scared to see casters going up that mesh...
As for the omni-wheels, I think you'd probably be safe with them, as long as you get ones that ARE NOT METAL, and you find a way to make sure they DO NOT GO THRU THE MESH. Cause if they are metal, or they do go thru the mesh, ur toast.
We're just makin our own wheels......and I must say that they are sexy.....I'll upload some pics once I get some pics (makes sense...)
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
steel tubing BBFIRSTCHICK Rules/Strategy 2 14-01-2003 22:03
Which wire mesh will be used? Jacqui Sutton Rules/Strategy 1 07-01-2003 00:51
Can tread protrude through the wire mesh? Randy Ai Rules/Strategy 1 06-01-2003 17:17
steel plate ........legal dimensions? archiver 2001 1 24-06-2002 00:32
Legality of steel tubing. newy Rules/Strategy 3 01-02-2002 09:16
