Go to Post FIRST is more than FRC. - gblake [more]
Unread 23-01-2003, 09:41
Dave Dave is offline
#0654 (Mechateuthis Dux)
Dave is an unknown quantity at this point
Send a message via AIM to Dave
Drill Motor Problemos
Errrmm.... Ok... this could be less than good,
We put some white tape on the flexible coupling, mounted an optical sensor above it, and breadboarded a resistor onto the output diddly-boob. Anyhow, with the help of an oscilliscope, we found that rpm were about 320.. not a good figure. Also, there was a 15% difference between forward and revers, but that was sorta expected. What kind of rpm are you guys getting on the gearboxes, no-load?
I like shiny moving things... perfect!
Unread 23-01-2003, 10:58
gc02 gc02 is offline
gc02 is on a distinguished road
Did you check the battery's voltage to make sure it's 12V, or better yet, check the voltage at the motor's terminals? What is connected between the motor and the battery? Is there anything connected to the output shaft?
Greg
Enigma Industries
Unread 23-01-2003, 11:03
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
It is the listed speed, I tested it with a strobemeter (verry accurate), also the opt sensors responce time is >1ms
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
