Go to Post Cant get hair and nails done and still run a robot. - wendymom [more]
Unread 24-01-2003, 18:12
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
Rookie Year: 2000
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
Gear reduction question
If two gears/pulleys, different sizes say 60 teeth and 20 teeth are sitting on the same shaft next to each other, is there a reduction factor between them? If so, how is that factor used with other reductions being used? Are they multiplied or added? Thanks for any help.
David M. Ellich
Unread 24-01-2003, 18:17
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
There're more than a couple whitepapers about this topic.
You can find them here.
Also, How Stuff Works is a great resource for a great many things. They have an entire section devoted to gears and gear ratios.
Hope this helps.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 24-01-2003, 18:33
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Rookie Year: 2000
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Re: Gear reduction question
David M. Ellich
The way I figure these is I look at the rotations. If you have a 40 tooth gear interacting with a 20 tooth, which is on the same axis shaft as the 60, which is interacting wtih a 120, you would have:
40 teeth to 20 teeth = 1 turn of the first shaft results in 2 turns of the second.
Now your going from 2 turns from a 60 tooth shaft to 4 turns on the 120 tooth gear.
i think i did this right...although, i am doing this last minute at my grandfathers house...so if im not right id love to be corrected..If I get time when i get home, ill put some 3ds images up.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 24-01-2003, 19:40
AKA: Mr. E
Rookie Year: 2000
I visited HSW some time ago and understand the basic concept of gear reduction. However, HSW does not address my question. Is there a reduction between 2 different size gears that are sitting on the same shaft, side by side and not meshed with anything else.
Unread 24-01-2003, 23:12
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
No reduction
If two dissimilar gears are mounted on the same shaft, then there is no reduction.
However, using this setup coupled with other gears is a good way to produce a reduction.
Here is an example:
A Fisher-Price motor has a 19 tooth gear.
This 19 tooth gear is mated with a 57 tooth gear, providing a 3:1 reduction translated to the shaft which the 57 tooth gear is mounted.
On that same shaft which the 57 tooth gear is mounted, there is another 19 tooth gear, attached to the same shaft.
Now, this second 19 tooth gear is meshed with a 4th gear, a 38 tooth gear, which provides an additional 2:1 reduction.
The total reduction of this system is a 6:1 speed reduction, done in a very small package.
Andy B.
Unread 25-01-2003, 00:00
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
In the attached picture, there is two ways for this to go.
I didn't count the teeth but i THINK the large are 48 Teeth, small are 16 teeth. This creates a 3:1 or 1:3 ratio depending on drive shaft.
Scenario A:
Brown is driven at 27 RPM
Brown spins Small Blue at 81 RPM [27 * 3]
Small Blue is attached to Large Blue therefore BOTH Blue spin at 81 RPM.
Large Blue spins Red at 243 RPM [81 * 3]
Final: 27:243 = 1:9
Scenario B:
Red is driven at 27 RPM
Red spins Large Blue at 9 RPM [27 / 3]
Large Blue is attached to Small Blue therefore BOTH Blue spin at 9 RPM
Small Blue spins Brown at 3 RPM [9 / 3]
Final: 27:3 = 9:1
Unread 25-01-2003, 08:54
AKA: Mr. E
Rookie Year: 2000
Thanks Andy and Gadget, your responses answer my question perfectly!
gearing design calculation question caffel Motors 4 24-03-2003 17:34
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
