Go to Post Parking Lot T-Shirt Bootleggers are NOT approved suppliers - Rich Kressly [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 25-01-2003, 12:09
Pylos Pylos is offline
#0093 (N.E.W. Apple Corps)
Pylos is an unknown quantity at this point
Send a message via AIM to Pylos
inventor to max
hey i have a problem i read the thread that shows you how to import inventor files to max but it doesnt work is there any other ways to?
go team 93!!!!
Unread 25-01-2003, 15:26
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
You can save your Inventor files as .IGES.... but it's really a horrible way to do it, since Max recognizes it as one whole part... Sorry I'm not much help, try contacting Autodesk.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 26-01-2003, 00:49
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
There is actually a 3ds max plugin for importing inventor files (either parts or assemblies), but for some reason it only works for 3ds max4 and inventor 5 (at least on my computer). Try searching for an updated plugin. If you cant find anything, i would recommend exporting the part files in an .STL file, which is in my experience the best format for Inventor-to-3dsmax transfer. Just play with the settings in the max import dialog to get the best results.
Unread 27-01-2003, 11:56
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
the .stl files are for parts only.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 27-01-2003, 11:58
FUN Show Host
Re: inventor to max
well since I didn't notice that pylos was on my own crew, you shoudl know that I have already addressed this problem on the boards. .
CD Moderator
Unread 27-01-2003, 22:52
i found one that i think will work but our school blocks downloads!
if any of you find on for 3ds max 3 could you please attach it so i can download it. that would be grate if you could.
go team 93!!!!
Unread 29-01-2003, 09:36
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Rookie Year: 1999
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
go to the inventor menu, and go to export file, and select .3ds as the file type(i don't know if all this is in there.. i haven't used the program that much..) and then when you go to 3dsmax import the 3ds file, try that and tell me if that helps.. if you don't want to do the download thing that is...
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 29-01-2003, 15:24
Lev's Avatar
Lev Lev is offline
As far as i know there is no "export to .3ds" option in Inventor.
But i did find a working plugin for Inventor 6 and 3dsmax5 (and 3dsmax3 and 4 as well) - you can download it here: http://adeskftp.autodesk.com/prodsup...Max_Plugin.zip (and the installation instructions are found here: http://www.mekvizion.com/Support/Max...gin_Readme.txt )
Hope this helps
Unread 30-01-2003, 08:41
FUN Show Host
Ummmmm, there is no export to .3ds, however, use the method that I suggested on the boards.
CD Moderator
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
FIRST MAX Animation Tutorials Robby O 3D Animation and Competition 2 01-02-2002 22:53
Ahhhh! I've had it with 3dstudio max! AnnyRob 3D Animation and Competition 6 29-01-2002 11:23
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
