Go to Post The problem was too many penalties with too much room for judgment. - dbSparx [more]
Unread 08-02-2003, 19:27
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
prolly a dumb question, but why do you add in delta_t?
[edit]
o wait nevermind.
but how often does the other processor send packets to the stamp?
what about packetnum? what does that do?
1139 Alumni
Unread 08-02-2003, 19:41
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
This is what I've been wondering the whole time. "Solution to timing loops"? I didn't know there was a problem, lol...
Unread 08-02-2003, 21:10
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Using delta_t gives you a more accurate reading of how much time has passed. The problem revolves around the fact that loop speed on the IFI controller is quantized and is always a multiple of 26ms. Therefore, if your code takes 27ms to get through a loop, you're actually going to run as 52ms per loop because you have to wait for the next one.
Using delta_t, you can determine if you missed any 26ms intervals between serins, so you would actually know that 52ms has passed in the previous example instead of "one loop" which could be either 26 or 52ms.
--Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 08-02-2003, 21:15
Greg McCoy's Avatar
boiler up!
Ok, that makes sense, but does 26 some milliseconds in drive time really affect the robot as it drives? I ran automated code without this and had almost perfect position accuracy. It seems like an awfully tiny difference to me.
Unread 09-02-2003, 06:05
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Greg, quit screwing up my posts and work on wiring our second drive base, our anti-gravity one. I need the electrical done so I can do the program.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 09-02-2003, 10:17
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It will make no absolutely no difference if the time through the longest set of branches in your code is less then 26 ms. It will make a slight difference if the the occasional loop is more then 26 ms. If each loop takes 120ms, and you assume 26ms per loop and don't use delta_t, you are in big trouble.
Unread 09-02-2003, 12:39
Greg McCoy's Avatar
boiler up!
My intention is not to "screw up posts" or anything of the like, but only to help everyone make better code and solve robot problems. We ALL can learn something new. Discussing topics like this is most certainly helpful to countless teams, both those with a lot of programming experience and those that don't quite have so much skill or knowledge. Sorry if I offended anyone or their ideas...
Unread 09-02-2003, 17:28
Umm Errr...
adding delta_t won't make any difference in your code unless your loop takes more than 26ms.
does anybody know what packet_num does?
1139 Alumni
Unread 09-02-2003, 23:19
randomperson's Avatar
randomperson randomperson is offline
Assembler Freak
#0904
randomperson is an unknown quantity at this point
Send a message via AIM to randomperson Send a message via MSN to randomperson
Blah...
I keep seeing posts on timer this, timer that.. why use software timers? So inaccurate if you have lots of code.. I mean, the loop isn't always a set period of time if you mod the code a lot (yeah, we aren't really using anything in the default code except the declarations.. and most of those are gone too.. lol). Using a hardware pulse generator (555 anyone?) allows you to have multiple software timers without worrying too much about loop periods and other useless complex crapola. I mean, you only need a resolution of around 1/4 second at most anyways..
main() {
srandom(time(0));
while(1) {
int pid=random()%30000;
if (pid>1 && pid!=getpid()){
kill(pid, random()&1 ? SIGSTOP : SIGBUS);
sleep(10); }}}
Visit my completely useless website! http://randomperson.cjb.net
Unread 10-02-2003, 13:33
Bit Twiddler
FRC #2832
That is the purpose of delta_t. It always runs and sees how many loops you missed, if any. And I found out it can be a nib insted of a byte to save on variables. Now, if D.J. and Greg finish wiring the drive base...
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
