Go to Post Ineveitably what we do just might end up in the hands of millions of people. - JoeXIII'007 [more]
Unread 26-01-2003, 15:54
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Unhappy Broken Breaker
Has anyone else had a problem with their 120 amp breaker? Ours is broken. The nifty little reset switch won't stay in the reset position!
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 26-01-2003, 15:58
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
It is disconnected from everything and still wont stay in the reset position?
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 26-01-2003, 16:02
Correct.
CORRECTION
On what I had here, I need to make a correction. The breaker always allows a connection to go through unless you hold in the red break button. It's as if the reset level has been disconnected from something on the inside. Unfortunately the breaker was pop-riveted together in Mexico, so we can't crack it open and try to fix it.
Anyone know if this is a common problem?
www.burobotics.org
Unread 26-01-2003, 22:28
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Originally posted by generalbrando
Correct.
CORRECTION
Hmmm.....I forget what this breaker looks like, as I have only held it in my hand for a short time. ( we are PROTECTING all kit parts...especially these "new" parts we don't have an old spare of)
If going to FIRST for a replacement fails, the only thought I have is that you identify the vehicle this breaker comes from, and rush out and purchase it ASAP. (I hear that financing incentives are ending soon ;-)
Take the breaker out of the car, convert the car to a war-wagon, and your all set. (and your robot will have a nice comfortable set of wheels!)
Good luck,
-Quentin
PS: Sorry....I'm a little whacky after a marathon week of working on a controls PCB that is being scrapped fro the design.
Live free or die....
Unread 26-01-2003, 23:28
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Theise breakers are a pretty common thing, Ive used them a bit in my work with car accessories, id say just search around the net and you should be able to buy one if first wont give you another (which they should)
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 26-01-2003, 23:40
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Breakers
We have used these breakers in the OCCRA competition for the last three years. I have never seen one fail.
I can get you our source if needed. PM me and I will see what I can do for you if you still need it.
Mike Martus
Unread 27-01-2003, 14:20
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The RED push button on top of the breaker is meant to open the breaker. The little black flag that comes out is the actuator to indicate that breaker has been tripped. Reset is accomplished by resetting the black flag into it's covered position, i.e. not visible.
This breaker is a big improvement over last year. I have not been able to make it trip with shock in any orientation although I have tried many times. I have yet to fully test under load, but suspect that since this product was designed for vehicle use, we will be satisfied with it's performance.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-01-2003, 21:13
Thanks
Thank you all for your input. It looks like this is a fluke (lucky us) since no one else has had a problem. The part is on it's way back to FIRST and we'll have a replacement soon (crossing fingers).
www.burobotics.org
Main on/off breaker Brett W Technical Discussion 4 07-01-2003 23:35
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
circuit breaker archiver 2001 2 23-06-2002 23:18
60 amp breaker Anne Lam Technical Discussion 10 10-01-2002 15:13
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
