Go to Post DONT USE ROBOTS FOR EVIL!!! - Cooley744 [more]
Unread 26-01-2003, 16:58
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Rookie Year: 2000
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Question Victor 884
Does anyone know what the major difference is between the 883 and 884 Victor. We now have a box of "useless" 883's and have to buy four more 884's at $115 each. This recent revelation is really putting a damper on things and would be more palatable if the difference was truly necessary.
Unread 26-01-2003, 17:04
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
I thought i saw somewhere that the 883s had a deadspot where you had to apply a certain amount of power before they would actually kick in.
Unread 26-01-2003, 17:21
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
Here's an ASCII of what I think the difference is in PWM width vs. requested counts:
Code:
883
|     |__|
884
|     \__/
Basically, I think both have a dead spot with the 884 having a smoother transition from the dead spot to an active state.
Unread 26-01-2003, 18:11
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
I think I read somewhere that you can only use 884s for this year's competition, not sure but you might want to check the manual or something.
Unread 26-01-2003, 18:43
Dave... Dave... is offline
#0005 (Robocards)
Dave... will become famous soon enough
The Victor 884s are capable of up to 40 amps, rather than 30 amps, and they also have a power range of 3%-100% rather than 10%-100%.
According to Innovation First, this should mean better (more precise) arm control.
Kevin, is your team interested in selling your old 883's?
Unread 26-01-2003, 19:24
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
No, we just think its unfair to not let us use them for the motors that dont require 40 amps, some of us are personally paying for parts out of pocket due to lack of funds, and just having these lay around and not be able to use them is bad. We dont like the idea that we are forced to buy more from innovationfirst even though they are not a safety hazard and will work just as well. I begin to wounder what the exact pourpose of that rule was trying to accomplish, as far as I can see - only to force us to buy new things we already have just so they can make more $$$
Unread 26-01-2003, 19:33
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
I agree completly, we have about 6, 883's just lying about and can't use them. It's rather frustraing
---Lightning Robotics!---
Unread 26-01-2003, 19:44
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
hooray for rookie teams who don't have old parts
i wish i could help you guys out. the best thing i can tell you is put 'em on ebay...battlebots people eat those things up. you'll atleast make a little money back...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 26-01-2003, 22:16
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
I can think if several reasons for the ruling.
1) It makes it easier for judges. They con't have to INSPECT to make sure you have a particular speed controller n a particular motor on a particular fuse.
2) Its called leveling the playng field. It will keep older teams from having such an advantage over rookie teams.
3) Then there is of course safety....probably the big reason. Another 30% current is not insignificant....(though safety also goes along with reason #1)
-Quentin
Live free or die....
Unread 26-01-2003, 22:42
#0588 (Team 588)
What would it matter about inspecting it? The current limit on the 883s is lower. It would actually be safer. It wouldnt really matter about what breaker you put upstream from it. No need to inspect. There was no extra inspection when a team used 884s instead of 883s last year.
Allowing would level the playing field because teams with less money could afford to have more speed controllers or hold them as backups.
Unread 26-01-2003, 22:45
RebAl's Avatar
-Quentin
1) The electrical system should have all the wires traced anyway to make sure it is the proper gauage for the motor and fuse used, and the maxi breakers are hard wired anyway so finding their attatched victors shouldent pose a problem, just in the same way they must trace a relay to a motor to make sure it is legal
2) It would be less of an advantage because it does not have the same current and it does not allow you to use all of the power as mentioned above, only advantage would be not having to pay $$ but at the same time having a old victor
3)If the victors are attatched to the correct fuses there is no safety hazard
Also what if a team bought 5 victors from years before, are they useless just because they dont have the same features that first feels we need? I guess our team will have to cut down spending in other places, like for the nats because of this extra 650+ expence.
Unread 26-01-2003, 22:52
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
transorbers and emc?
I can think of 2 more reasons to get rid of the 883's
The 883's came in 2 flavors "red" and "blue" The older ones (can't recall which was which) required an external transorber to suppress transients to the rest of the wiring harness. Perhaps they just got tired of having to explain to inspectors when to look for external transorbers and when not to?
A more serious issue may involve electro-magnetic compatibility.
The 883's had a PWM frequency of something like 1000 Hz (perhaps more, again, memory fades...). Victors use something more like 100 Hz.
I am only a mechanical engineer, but I think that the following two things are true about this change in frequency:
#1, Your motors will start to move at lower duty cycles at 100Hz than and 1000Hz (in effect, the motor's time constant acts like a filter that filters 1000 Hz more effectively than 100 Hz)
#2 1000 Hz will act more like a radio station than 100 Hz
It is my understanding that Innovation First is working on new radio system for their EduRobotics that they are looking to migrate to their FIRST product.
Lower EMC problems may be an important factor in making the switch.
Finally, Innovation First may just be tired of supporting the older product. If this is the price of keeping Innovation First in the business of making control systems for FIRST, it is well worth it. As an 8 year veteran, I can say without hesitation that we are much better off with Innovation First than without them.
In any case, it is a hardship, but it is not an undue one (imho) especially since we have the K3 rule limiting how crazy we can get with extra Victors anyway.
Just my 2 cents.
Joe J.
Unread 26-01-2003, 23:14
D.J. Fluck
Posts: n/a
Put the 883's on ebay. They should sell for at least 50 dollars a pop. Ive heard that there was a team once that did that and they got back 60-65% of the value of them from the auction. Have the winner pay shipping and you could make back a nice sum of money
[edit] On EBAY I found a set of Victor 883's for $175 for a set of 2....they do sell. (The guy put BATTLEBOTS in the title, but whatever sells them) [/edit]
Unread 27-01-2003, 02:53
BSMFIRST BSMFIRST is offline
no team (-)
BSMFIRST is on a distinguished road
http://www.ifirobotics.com
>>On EBAY I found a set of Victor 883's for $175 for a set of >>2....they do sell. (The guy put BATTLEBOTS in the title, but >>whatever sells them)
Those were probably not the 883's you guys have laying around.
Check out http://www.ifirobotics.com . That's the non-FIRST (ie BattleBots) side of Innovation First. They have a 24V Victor 883 that is rated at 60A.
You're right though, the BattleBots folks will buy the old 12V 883's--the lower weight classes robots (30, 12, 2 and even 1 lb) are getting popular.
Dan
  #15   Spotlight this post!
Unread 27-01-2003, 02:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Try eBay in the RC car section. People pay way too much money for speed controls in there.
