Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 26-01-2003, 17:30
MARobotics MARobotics is offline
MARobotics is an unknown quantity at this point
Question Maxi Block Troubles
Hi, I was just wondering how to use the maxi block with the 40 A circuit breakers. There are 4 red wires coming from it--where do they go???? Also, how do you hook up the motors to the block (our kit was missing the curcuit breakers for the block). Thanks for the help
Team 766
MA Robotics
Bad robot.
Unread 26-01-2003, 22:19
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Maxi Block Troubles
Team 766
MA Robotics
I have not looked at the block myself...but I can only suggest to you what I will do too....go at it with an Ohm meter and figure it out.
It seems to me that it is probably one of two things....all read leads are shorted together inside, or each one does to one of the breakers.
I would bet on the latter...though the ohm meter will not lie!
Good luck...
-Quentin
Live free or die....
Unread 26-01-2003, 22:27
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The kit includes a basic electrical blueprint type diagram thing.
http://www2.usfirst.org/2003comp/rob..._blueprint.pdf
Connect the screw on the Maxi Block to the positive lead on the 120Amp breaker, and connect each individual wire coming out of the Maxi Breaker (4 total) to the speed controller which will be controlling either a drill motor or a CIM. The negative lead on the speed controller can be connected directly to a ground plate on an old-style fuse block.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 27-01-2003, 07:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
As you look at the block, you will see where the large bolt is attached, is a metal plate. This is in common with all four positions of the breaker slots and is intended to be connected to the 120 amp circuit breaker. The four leads are attached to each of the four breaker positions opposite from the common and go out to whatever motors you intend to drive from the 40 amp circuit breakers. If you do not need the 40 amp circuit breakers, then the maxi block can be left out of your design.
Al
WB9UVJ
www.wildstang.org
________________________
Wicked Easy Way To Block Pop-up Adds! MattK Website Design/Showcase 18 17-02-2003 20:33
Common For MAXI MikeDubreuil Electrical 1 10-02-2003 02:35
Maxi Block Confusion? Adam Shapiro Electrical 11 26-01-2003 20:23
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
Any way to block out certain forums? Ken Leung CD Forum Support 5 02-09-2002 22:07
