Go to Post Heck, every human being has the potential to change the world, as long as the world still exists. - [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 27-01-2003, 18:16
BC1022 BC1022 is offline
BC1022 is an unknown quantity at this point
Bitmaps as texture in 3ds max?
First time using 3ds max and I'm having trouble loading bitmap images and using them as material textures. It seems like you can only load them as maps and for some reason I can't apply the maps to objects. I've tried searching through tutorials but haven't had much luck. I basically want to add textures I create to the animation. Any help would be great! Thanks.
Unread 27-01-2003, 19:51
MBiddy's Avatar
MBiddy MBiddy is offline
Groovy!
#0862 (Lightning)
MBiddy is an unknown quantity at this point
Send a message via AIM to MBiddy
You can't load the bitmap directly as a material, you have to use it as a map on a material. Select one of the Default starting materials and scroll down to the Maps rollout. Next to Diffuse click the button in the Map column (it should say "None" right now) and click Bitmap in the list that come up. Then you can choose an image to act as a texture. You'll probably have to deal with scale and UVW mapping coordinates to get it to look right.
Unread 28-01-2003, 07:23
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
adding to that...if you add the map to other bitmap to other slots (bump, displacement, refelction) you can get some very realistic results.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 28-01-2003, 18:32
bitmap textures
Thanks, I'm actually getting it to work now
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
I NEED MAJOR 3DS MAX HELP!!! Ranma 3D Animation and Competition 3 28-02-2002 07:22
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
