Go to Post I was dragged to the first team meeting in September my freshman year and a week later, found myself at Fall Classic. Needless to say, after experiencing the heat of a competition, I was in love. ... Robotics has become far more than just that. I get to do the coolest thing in the world. - Audrey Chu [more]
Unread 28-01-2003, 06:57
Dr.Bot
Posts: n/a
Spacers in FIRST gearboxes
The latest exploded diagram on the FIRST doc pages shows "spacers" being used along with the locking clips and key stock to assemble the gear boxes and make sure the gears don't drift off the shaft. Has anyone found a good way to make these spacers if you dont have a machine shop? Iwas thinking maybe 3/4 inch pvc or other plastic pipe. A whole bunch of washers is messy and adds too much weight.
Also is it just me, or is mounting the gears with the supplied keystock a bear? Seems the key stock is harder than the shaft but softer than the gears - is this the way it is supposed to be, or is there some magic tempering trick?
Unread 28-01-2003, 08:47
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
There is no need for a machine shop for any of this. Just a little elbow grease. All you need to do is cut the spacers with a hack saw, and make sure you file it out afterwards. It doesnt need to be perfect, but make it as close as you can to the actual measurments. The stock for the spacers was provided in the cardboard box with the 2x4 aluminum extrusion. As for the keys, just cut them with a hacksaw (slightly smaller then the width of the gear) and hammer them into the shafts keyway. then slide the gear over and use a mallet to hammer it down the shaft. Thats what our team did. We have a machine shop, and the gearboxes needed no machining. The thing that needs the most machining in my opinion would be the shafts, which I chamferred and faced off, it makes it much easier to get the gears and bearings on the shaft.
Unread 28-01-2003, 09:45
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
Sometimes filing a little start on the keys help the get started the the key slot. make sure you don't have any burrs on the mating pieces. If it is to loose just use a drop of super glue to hold it. It will hold it in place and can easily be knock out if you need to remove the key.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 28-01-2003, 13:03
Dr.Bot
Posts: n/a
Oh, so that is what that aluminum tube was for!
BTW I think 3/4 inch pvc will also work the inside needs to be reamed slightly, or cutting a slot on one side would work. A 3 fot piece of PVX 3/4 pipe costs 36 cents.
Unread 31-01-2003, 03:02
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Does anyone have the lengths for the spacers and axles for FIRST's drive train as shown at http://www2.usfirst.org/2003comp/Drive_Train-expII.pdf.
I am trying to get some students to assemble that drive train while we work on our other one.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 31-01-2003, 07:51
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Axial thrust load for helical gears
You need to be aware that helical gears like the ones supplied for the gearbox generate considerable side (axial) thrust. That is, the gears try to slide sideways along the shaft when they are subjected to a load. The equation for this axial thrust (from Boston Gear's website: ) is:
Axial thrust load = (126,050 x HP) / (RPM x Pitch diameter)
So, for the large gear when driven by the drill motor in low gear, RPM = ~450, HP =~ 250watts/746 watts per HP = .34, Pitch Diameter of the 1224 gear = 2"
Axial thrust load = (126,050 x .34)/(450 X 2) = 190 lb. This suggests that you would be wise to use the aluminum tubing provided, and not PVC pipe.
Unread 31-01-2003, 12:53
Dr.Bot
Posts: n/a
I think that the key and the lock washers would do more to fix the gaers in place on the shaft would provide considerable "grip" on the gear. The spacers are mostly for spacing, and really don't provide a lot of structural strength.
As to precise measurements for spacers, the aluminum is soft enough to work easily, so a hacksaw and a file should be adequate to cut(slighty big) and fine tune the spacer. So I think FIRST is correct in saying the Chasis could be easily built with handtools. The only reall hard part is making a hole for the axel through the square aluminum
tube. Hard to drill a hole that big with hand tools. A small hole could be drilled and then enlarged by hand filing, While a spurred wood spade bit in a drill press would work - I don't feel that is a very safe method.
I think we will get 5fps with the FIRST supplied drive in low gear.
Unread 31-01-2003, 19:36
Dick Linn's Avatar
Dick Linn Dick Linn is offline
no team (Synergy)
Dick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond reputeDick Linn has a reputation beyond repute
Send a message via AIM to Dick Linn
gearbox spacers
I would not depend on banging in keystock and having the gears stay put and in proper alignment. We initially hacksawed spacers just a wee bit long, after using a magic marker and the jaws of a vernier caliper to scribe a line at exactly the right length. The trick is sawing part way through, all the way around, right next to your scribe line. Otherwise you don't get a straight cut. With practise, I could get within a few hundredths, but it's a bit of work. Then the trick was to file the ends parallel and make each pair the same length. Still, we managed to get a number of them to within, I'm guessing, .010 of what they should be. Later we got a cheap $4 tubing cutter, which makes it a whole lot easier to cut the tube straight, although you still have filing to do. I used a short piece of 5/8 inch wooden dowel clamped vertically in a vise and let the spacer protrude just a bit above when filing.
I measured the gearbox and the tubes are nominally .750 for the short ones and 1.1875 for the long ones. This is without any spring preload washers. I still do not know how much shorter to make the spacer tubes in order to properly preload things using the spring washers that came in the kit. (These are the slightly cone-shaped steel washers.) They are too large in diameter for the small gear but can butt up against the large gear. If the spacer tubes are too long, these axle assembly will push too hard against the bearings and create a lot of friction. For now, we're trying to use only the tubes, make each pair on a shaft exactly the same length and end up with little or no slop.
If you do get spacers of equal length but get them a wee bit short, you may be able to find extremely thin shimming washers to add to each end to take up any slop.
Richard Linn
Proud father of Marine LCpl. Karl R. Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-02-2003, 09:06
Dr.Bot
Posts: n/a
I didn't say "don't use spacers." I said the aluminum is soft enough to be easily worked by hand. If the keystock is cut too long, the aluminum can be easily notched. Once you know how do it, it is possible to build a working chasis and drive system in a day with only hand tools. (2 hours is pushing it!)
Mounting the gear boxes and motors on the aluminum takes patience. The wheel mounting plate can be used as a guide. It is notched to fit the square alu0..000000000(that was my son's kitten typing) aluminum. use a center punch to locate the holes then use a drill press. I suggest step drilling (start smaller then go bigger 3/16, 1/4. 5/16) Use washers and lock washers. When the gear box is mounted and snugged up, make sure it still turns freely. Andy binding would be a source for concern. I would mark and mount the motor after the gearbox was in.
Unread 02-02-2003, 19:07
ROB at RAGE ROB at RAGE is offline
ROB at RAGE is an unknown quantity at this point
Drilling aluminum with hand tols
Buy a step drill bit, they are sold in many catalogs as well as any good hardware store. They make drilling holes in aluminum (and plastics go almost like butter (espically lagre ones). Use a little oil on the bit for metals also.
Unread 02-02-2003, 19:28
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
Shaft Collars
To avoid using a spacer, I would suggest that you look for a shaft collar. If the axial loads are too great to be held by a shaft collar, then my next choice would bve to use the Al tubing. If you cut it to a rough length, you can file it to the right square length. This does take some time, but taking shortcuts doesn't pay off with drive systems. As for the PVC, if you use Schedule 40, it will probably be OK. It is good under compression.
Hope that helped!! Good luck!
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 02-02-2003, 20:49
Cutting Aluminum Tubing for Spacers
If you got a pipe/tubing cuter use it. You can also cut it with chopsaw for wood if it has a carbide tiped blade, coating the blade with some bees wax keeps it form getting loaded with aluminum. Clamp the tubing down and don't use your hands with the chop saw. A band saw with a metal or wood blade usually cuts aluminum well also.
If you have to hacksaw it, you can square it up on a belt or disc sander.
Which team do u think used firsts gearboxes the best. 18voltMilwauke General Forum 5 17-04-2003 12:01
team 151's gearboxes Greg Perkins General Forum 3 29-01-2003 23:01
Trade - have Bosch gearboxes, need motors Andy Baker Motors 0 24-01-2003 08:32
gears....? archiver 2000 16 23-06-2002 22:58
Drill Motor Inconsistency archiver 1999 10 23-06-2002 22:34
