Go to Post ADMIT IT! Dave Lavery has better legs than Amanda Morrison! - DCA Fan [more]
Unread 28-01-2003, 22:18
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
how would U determine the exact speed of your robot?
Just wondering how you guys would determine the speed of your robot if you wanted a pretty exact number.
Unread 28-01-2003, 22:24
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Tape measure+stopwatch+calculator
Unread 28-01-2003, 23:00
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
That's really it.
Just one other thing to remember, will your robot be stopped when you begin timeing, or will you let it get up to speed (have it start before the line)? - This wouldn't have as much of an effect the further the distance, but I'm assuming that you're only going to have it go 30-40 ft, in which case, it would make a difference.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 28-01-2003, 23:20
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
If you wanted to do it with calculations, you can figure it out theorhetically. You need the diameter of your wheels. With this, you can find out the circumference of your wheels with:
Circumference = (Diameter) * (pi)
Then, you need to figure out what speed your output shaft revolves at. You can figure this out with:
Shaft speed = (Motor free speed) / (Gearbox & sprocket reduction)
Then, just multiply the shaft speed (rev/sec) by the wheel circumference (ft/rev) to get the speed (ft/sec). For all practical purposes, I would multiply the speed # by 0.90 or 0.95 to take in account a 90-95% drivetrain efficiency. You're not going to get 100% of the motor speed to your robot wheels.
For example, last year we used the Chiaphua motors geared overall 30:1, with ~7" diameter wheels (including traction material). The Chiaphua rotates at approximately 5400 revolutions per minute, or 90 rev/second.
Circumference = 1.83 FT
Shaft Speed = 3 rev/second
Speed = 5.5 ft/second
Of course, the most accurate way is tape measure + stopwatch + calculator, as said above. Get your robot up to speed, and let it go for 50FT (the longer, the better, the less error). Time how long it takes to travel this distance, and divide the length by the time.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 29-01-2003, 09:44
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Rookie Year: 2000
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
we measured the distance of our practice playing feild *38ft* and then ran a stop watch. it did 38' in 4.1 seconds, so that would be 8 ft/second and change.
Bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
Final Robot Speed kacz100 General Forum 8 03-02-2002 16:47
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
