Go to Post Pros of living in California from a Canadian standpoint: FRC on-field glass doesn't occasionally have shoe marks on it - Edxu [more]
Unread 30-01-2003, 11:39
Da_Huss_Don Da_Huss_Don is offline
#0902 (Robohawks)
Da_Huss_Don is an unknown quantity at this point
Question need Linux guru
help? I need a dual-boot system. I tried to install red hat 8 and it didn't recognize my partition...
I have:
lots'o'hard drive space (FAT32)
Windows 98SE (and approiate install disks)
the correct version of FIPS for FAT32
the Linux install disks (obviously...)
a decent understanding of command-prompt linux operation
help? I havn't found a good site yet with an answer to this question
"Try not.
Do or do not.
There is no try"
"I am not afraid"
"you will be...You Will Be..."
-Yoda
Unread 30-01-2003, 12:50
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
www.tldp.org
it's a great site...you should really read their newbie guides. it's better to learn linux on your own, and on your own flavor. different distro's have diff commands and some don't include all the programs and such...so it's better just to read tutorials and learn it on your own.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 30-01-2003, 15:48
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
To create a partition, you need to use FIPS. I think what FIPS does is split an existing partition into 2 parts. To install Linux, you need at LEAST 2 partitions. One for / and one for swap memory (swap memory is like Window's virtual memory). Uhh. When you split the partition, the big one needs to be formatted to most likely EXT2 (or Extended Linux...something like that)...and the smaller one should be Linux Swap or Swap Space... Your swap partition should be double your RAM up to 128M. Recently swap space hasn't been that important due to the cheapness of extra memory.
If you can't change partition types in FIPS, you can probably use FDisk in linux during the Redhat installation. The Windows FDisk WILL NOT work for what you want to do.
If you read the Redhat installation manual, it should give you a much better idea what to do. Take a look at page 45.
Wow...it's been a long time since I've played with those graphical installations
If you have many more questions, I can possibly answer them...or direct you to a better forum to ask them in: www.linuxnewbie.org
http://www.redhat.com/docs/manuals/l...-x86-en-80.pdf
I haven't played around in Redhat since 6.1...I don't remember how it works
And if you have no operating systems on there yet, install Windows first. If you don't, you'll have to reinstall and reconfigure your boot record to be able to start both Linux and Windows.
Actually, glancing quickly over the installation manual, I notice that you may not need to partition the way I said. I think RedHat has tools in it's installation to do it. Much easier than what I said
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Linux SteveC116 3D Animation and Competition 22 25-03-2004 15:07
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
Linux file extensions rbayer CD Forum Support 5 14-11-2002 23:04
MS Linux D.J. Fluck Chit-Chat 5 21-05-2002 17:47
