PBasic Select Problem
Greetings,
I have chosen to use the new SELECT construct in PBasic. Here is the code fragment: 'Dead Reckoning Code Select stepnum CASE 0 : gosub go_home CASE 1 : gosub go_home2 CASE 2 : if rc_sw3 = UP & rc_sw4 = UP then gosub go_left else gosub go_right CASE 3 : gosub go_forward CASE 4 : if rc_sw3 = UP & rc_sw4 = UP then gosub go_left else gosub go_right CASE 5 : gosub go_longforward ENDSELECT When I check syntax, it always highlights the stepnum variable and provide the following error: Expected ':' or end-of-line Error: 129-Expected ':' or end-of-line What causes this error ? Searched and couldn't find anything. Am running the 2.0 beta 1 editor. It acts like it doesn't understand the new language features. thanks in advance. |
| Ok one problem | cantwell03 | Programming | 3 | 13-02-2003 07:28 |
| RoboEmu 1.09 (supports PBASIC 2.5) | rbayer | Programming | 22 | 21-01-2003 17:22 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
| PBASIC problem | punarhero | Programming | 7 | 16-02-2002 23:13 |
