Go to Post theyre not planning on blowing up the comet... just running straight into it and seeing what happens. :D - Winged Wonder [more]
Unread 31-01-2003, 18:53
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Official Forum frustration.
I see I'm not alone in this, I think.
In this thread , ChrisH said,
In my question, which they declined to post, I pointedly asked that some codification be incorporated into the Rules through an official update. They basically said the "interpretations" on the FRC group ARE official and there was no need to do so. I hope they change their minds on that, the no need part that is.
I agree, entirely. Keeping up with the volume of questions and the myriad interpretations, answers, and 'official' rules changes is overwhelming and confusing.
I started a new thread to discuss this because the discrepancies between answers to the same or similar questions, outright changing of published rules, and FIRST's failure to make clear, concise changes in Team Updates has my team concerned.
In particular, one our critical mechanisms may now be in violation of these 'unpublished' rules, and while we are developing a backup, it's creating some undue hardhship. Maybe you all can help me with the interpretation.
Rule GM28 states,
Robots may not intentionally:
- Attach themselves to the railings/walls of any field structure.
GM31 reads, in part,
The outer field barriers are safety features of the playing field and robots should not be designed to react against them. Reacting is grabbing or using ... the top of the pipes at midfield ... with the intent of support a robot or robot part.
Specifically, rule GM31 makes no mention of reacting with the lower part of the midfield barrier.
We have a mechanism that was designed to tip over by contact with the lower part of this barrier - an action that seems to lie completely within the rules as they were published in the manual.
To quell my uneasiness, I watched the official forums with great interest. Particularly, I paid close attention to discussion regarding tipping the light down into the robot when going beneath the barrier. This isn't our function, but it's similar.
My question, as written, read,
Earlier, in response to this questions -
http://jive.ilearning.com/thread.jsp...c69676874#2264
- you say that it is acceptable for a some mechanism to react off the bar with the intent of lowering itself below the truss. Later, in reply to this question - http://jive.ilearning.com/thread.jsp...t=15&trange=15
- it seems as if you contradict your earlier ruling. Can you please
clarify? To what extent can parts of the robot contact the lower part of the midfield barrier? The rules, as written, do not prohibit any reaction with the lower pipe, short of damaging the playing field. If it is acceptable to design a light mount that rotates out of the way by contact with the midfield barrier, would other similar mechanisms unrelated to the light be allowed?
They e-mailed me a reply before posting it to the message board. Their reply, in private, was:
The intent of Rule GM31 is that the playing field structure is not to
be
used by robots to react against to gain a mechanical advantage. This
is
done, firstly, to protect the playing field structure components. We
envisioned robots trying to crawl over the midfield bar and in an
attempt
to prevent this, used the "top" of the bar prohibition. We also
anticipated robots going under the bar to avoid going over the ramp and
accepted this action. We allow containers to be tossed over the bar
but
not pushed under the bar. The rule states that you may use "minor
forces"
to contact the bar to activate sensors. We have expanded this
allowance to
allow teams to contact the bar to retract or shift the rotating
beacon. Other similar mechanisms that are used to sense the bar and
produce an operation are allowed. Other than incidental contact,
accidental contact or being forced into the bar by an opponent, the bar
should not be used for any strategic reactive purpose.
I cannot post question in the forum in the form that it is in. I may
shorten it so that it will be of benefit to all teams.
When they posted my question to the official forums, however, it was heavily edited, and their response was almost entirely different.
http://jive.ilearning.com/thread.jsp...=2&thread=1177
Now, I don't know which interpretation is correct. Should I be guided by what was written to me in private, which, by all accounts, seems to indicate that our mechanism is legal? Or, am I to assume that what was 'officially' posted on the forum is the true answer and what I was told never happened? I'm confused.
If the forums' answers are 'official' and the changes made there are not to be clarified in Team Updates, I think things may turn into a giant mess. Which one of the twelve different answers to the same question is the real answer?
With regard to our specific problem, how would you interpret the situation? We are designing a back up measure, just in case, but it's requires additional weight, money, time and resources that we don't have to waste.
Any ideas? Sorry for the length.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 31-01-2003, 19:29
Curtis Williams Curtis Williams is offline
#0588 (Team 588)
Curtis Williams is on a distinguished road
Send a message via ICQ to Curtis Williams Send a message via AIM to Curtis Williams Send a message via MSN to Curtis Williams Send a message via Yahoo to Curtis Williams
I think that they should go back to addressing rule changes and clarifications in the team updates only. It may take longer to get an answer, but I think it would eliminate conflicting answers.
Remember teathers? That hurt a lot of teams.
Unread 31-01-2003, 21:05
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Re: Official Forum frustration.
From all that, I get the impression that you can drive into the bar and activate something, but the bar itself cannot be the object which provides the force to do something.
Like, you CANNOT have the light spring loaded, and as you go under the bar, the bar itself pushes the light (or whatever device) down. Read: The bar cannot provide the force.
But, you CAN bump into the bar, and have that cause a motor to activate, and then have the motor move the light.
A trip device to lower or displace the rotating beacon is allowed as long as the lower bar itself is not used to force the light down to get under the bar.
(ie once the light gets bumped by the bar, a motor moves it down)
Does that help at all???
[Edit] I keep saying "light". But, I assume that the rule would hold true for other objects as well. [/Edit]
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 31-01-2003, 21:14
Firewolf's Avatar
Firewolf Firewolf is offline
lost
AKA: Shruti
Firewolf is an unknown quantity at this point
Send a message via AIM to Firewolf
We envisioned robots trying to crawl over the midfield bar and in an attempt to prevent this, used the "top" of the bar prohibition.
I don't like that,
why create a bar if you don't want someone to go over it?
warning: dyslexic and can't spell
ANTI-CLARIS
"TESMOIGN MON SANG MANUEL CY
We can do no great things... only small things with great love
Mother Teresa
Unread 31-01-2003, 22:11
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
It does not outlaw going over the ramp. You can still go over if you do not touch the top while doing so.
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 01-02-2003, 00:33
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Re: Re: Official Forum frustration.
Well, the answer they posted most recently on the forum corroborates your interpretation, and I guess it's the best we have to go with. It's just a whole ton of extra weight and time and resources down the drain, though.
I wouldn't have much to complain about, really, if FIRST were consistent about this. In many instances, both this year and last, it seems like the discussion forums lead to incomplete thoughts that become written rule. The problems and confusion just escalate and very little is solved.
If FIRST doesn't want people reacting against the bottom rail as well as the top, that's understandable and okay. I just wish they'd clarify that in a Team Update, remain consistent with their ruling, and - should they error - bite their tongue and accept the consequences.
We have to.
--Madison--
Unread 01-02-2003, 02:39
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
I'm with you guys on this one. Many times their answers are:
a) VAGUE. It's rather annoying when they just rephrase the question.
b) USELESS. It tells us nothing the rulebook doesn't say.
c) DISAPPEAR. They're "official" on the forum, but fail to make it into a team update.
It's not a very consistent system they use there...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 01-02-2003, 19:03
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
Originally posted by Firewolf
I don't like that,
Finally some one listens to me, there is 2 ways (well three but going through is difficult) you cna go overr or under
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 01-02-2003, 19:23
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
o rly.....
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 01-02-2003, 19:42
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
The thing that bothers me the most about the forums is the time they take to respond and the selectiveness in their responses. I have posted a few things and each time I am frustrated to see that some of the posts are answered, by mine goes days without being answered. You'd think they'd go down a list answering them one by one, but FIRST jumps all over the place. The Q&A team updates of the past were much better.
moderators for Q&A forum Ken Leung CD Forum Support 25 03-01-2003 18:15
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
