Go to Post Inspired by engineers and an innovative design. - JaneYoung [more]
Unread 01-02-2003, 15:21
LD8 LD8 is offline
#0599 (RoboDox)
Team Role: Student
LD8 is an unknown quantity at this point
Send a message via AIM to LD8 Send a message via Yahoo to LD8
Programming Prob-Analog sensors!!
When we look at the Dashboard viewer, we get a value listed under analog 1 from 0-255 however sensor1 is not receiving the value. Yes, all of the sensor1 one lines are uncommented and the serin line does include the sensor1 parameter. (What is the packet_num variable for?) Any ideas for what reason the sensor1 variable is not getting the value for analog 1 . Thanks,
Programmers in Need
Go Eagles!
Go Lakers!
Communications via the Programming Port Larry Barello Technical Discussion 9 10-06-2003 23:33
Robotics Tournament at Sensors Expo & Conference Kyle Fenton Off-Season Events 4 04-05-2003 12:15
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
pre-built autonomous sensors? BandChick Technical Discussion 4 05-01-2003 22:06
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
