Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 02-02-2003, 22:09
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
Sprockets and Roller Chain Models
Hey everyone.
I'm looking, specifically, for a 32 tooth, #35 ANSI Roller Chain Sprocket....whatever hub size will do. I can't find a model of one anywhere.
I do have Ed Sparks' i-Sprocket file, but when I try to insert anything about, say, 12 teeth, the sprocket explodes and it doesn't work.
I'm also looking for a similar roller chain file.
Can someone offer some parts or some advice or something? I'm just trying to put the finishing touches on our design.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 03-02-2003, 21:37
Unsung FIRST Hero
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Please Try Again ......
The early version of the i-sprocket had some troubles particularly with smaller sprockets. Download the current version and try again. If you are still having trouble, please let me know.
There is a good chain model at the cbliss website .
Ed Sparks
MECH TECH FRC-3959
Unread 03-02-2003, 23:06
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
Re: Please Try Again ......
Thanks. . .
I'll re-download the i-Sprocket and try it again.
I have the chain from the Cbliss site, but I can't make it work properly.
I'll play with it some more.
--Madison--
Unread 04-02-2003, 11:51
Madison's Avatar
FRC #0488 (Xbot)
Rookie Year: 1999
No luck.
I'm still having no luck with the i-Sprocket.
I've been able to successfully insert 10 and 12 tooth sprockets (I need 11 tooth, however. )
But, anything larger than that and it explodes.
[WARNING] Part1: Errors occurred during update <DcKernelRes(213)> [r:\core\Rd\Main\Component.cpp, line 503]
[WARNING] i-Sprocket.ipt: Errors occurred during update <DcKernelRes(213)> [r:\core\Rd\Main\Component.cpp, line 503]
[ERROR] Sprocket Blank: Could not build this Revolution <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] A profile loop could not be repaired after sketch geometry was edited or deleted. Use Edit Feature to reselect the profile. <RdRes(818)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 1888]
[ERROR] Sketch10: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 528]
[WARNING] Coincident constraint to reference geometry that could not be resolved. Use Edit Sketch to delete the reference geometry and rebuild the constraint. <RdRes(369)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 2333]
[ERROR] Sketch7: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 528]
[WARNING] Concentric constraint to reference geometry that could not be resolved. Use Edit Sketch to delete the reference geometry and rebuild the constraint. <RdRes(369)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 2333]
[ERROR] Tooth Profile: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] Cannot cut/intersect an empty part. Use Edit Feature to change the feature definition or Reorder the feature. <RdRes(843)> [r:\core\Rd\Main\Extrusion.cpp, line 2495]
[ERROR] Pattern Tooth Profile: Could not build this Circular Pattern <DcKernelRes(205)> [r:\core\Rd\Main\Pattern.cpp, line 2501]
[ERROR] All features involved in the pattern failed to execute; stopping pattern execution. Fix the problems for the input features. <RdRes(836)> [r:\core\Rd\Main\PatternUtil.cpp, line 731]
[ERROR] Hub: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] Work Plane1: Could not build this Plane by Offset from Plane <DcKernelRes(205)> [r:\core\Rd\Main\FeatUtil.cpp, line 2980]
[ERROR] Missing face/plane for offset work plane. Use Redefine Feature to change the work plane definition. <RdRes(406)> [r:\core\Rd\Main\RdDiagnoses.cpp, line 1406]
[ERROR] Sketch14: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 528]
[ERROR] Sketch12: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 528]
[ERROR] Bore: Could not build this Hole <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] Cannot cut/intersect an empty part. Use Edit Feature to change the feature definition or Reorder the feature. <RdRes(843)> [r:\core\Rd\Main\Hole.cpp, line 1349]
[ERROR] Sketch15: Could not build this Sketch <DcKernelRes(205)> [r:\core\Rd\Main\sketch.cpp, line 528]
[WARNING] Dimension to reference geometry that could not be resolved. Use Edit Sketch to delete the reference geometry and rebuild the dimension. <RdRes(367)> [r:\core\rd\rddiagnoses.h, line 656]
[ERROR] Keyway: Could not build this Extrusion <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] Chamfer3: Could not build this Chamfer <DcKernelRes(205)> [r:\core\Rd\Main\Feature.cpp, line 201]
[ERROR] Failed to save factory member <UcRes.dll(846)> [r:\Application\Uc\Request\UCxSetToMemberReq.cpp, line 873]
--Madison--
Nylon Roller Chain Sprockets Jim Smith Technical Discussion 6 20-01-2003 20:01
Ball Rollers archiver 2001 8 23-06-2002 23:26
