My team wants to know how do you power up the robot control, if the adapter only fits into the operator interface. PLEASE GIVE US SOME USEFUL INFORMATION.
the robot controller is powered from the battery onboard the robot.
Cory |
the robot control unit is powered by two twelve volt screws. run these through your twenty amp breaker. these screws are on the right side of the "Program" plug and say "12 volts".
You might want to go and get a mentor very quickly
These question can be answered by your mentor Good Luck |
Don't worry, reverse current wont hurt it.
We found that out after trying and trying to get it to come on . . . only to realize that the quick release thingy on our battery was backwards . . . . I didn't breath again until we tested it and it came on. |
yes, get a mentor, very quickly, that or read a book, or the white papers or something.
http://www2.usfirst.org/2003comp/rob..._blueprint.pdf These two documents should be able to give you an definitive answer. If you are still unsure, let me know and I will explain anything that you are not sure of. |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| RoboCon 1.01 (control robot from PC) | rbayer | Programming | 20 | 06-11-2002 21:30 |
| WASH Palm scouting at the Championship | Mike Soukup | Scouting | 2 | 19-04-2002 15:14 |
| Control System Power | Al Skierkiewicz | Technical Discussion | 0 | 25-03-2002 09:04 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
