Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 04-02-2003, 11:51
Dush's Avatar
Dush Dush is offline
#1166 (highlander)
Dush is an unknown quantity at this point
Question Drill Motor
HElp We CAn'T sEeM TO fiND A Way To KeEP OUr MoTORS lock IntO PLaCE
Unread 04-02-2003, 12:00
Chris Hibner's Avatar Unsung FIRST Hero
Chris Hibner Chris Hibner is offline
Eschewing Obfuscation Since 1990
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Rookie Year: 1997
Chris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond reputeChris Hibner has a reputation beyond repute
That makes two problems
You can't seem to find a way to make your Caps lock into place either.
Unread 04-02-2003, 12:16
Wes Wes is offline
#0758 (Roboticats)
Wes is an unknown quantity at this point
try taping them in
Unread 04-02-2003, 12:23
Dush's Avatar
#1166 (highlander)
Question
HaS N E One fiRgured How To LoCk The MoToR InTo PlaCE
**to secure ourselves against defeat lies in our own hands,but the opportunity of defeating the enemy is provided by the enemy himself**
Unread 04-02-2003, 12:27
Anne Shade Anne Shade is offline
Maryland Regional Director
AKA: Formely Anne Bergeron
no team (FIRST Chesapeake)
Rookie Year: 1998
Anne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond reputeAnne Shade has a reputation beyond repute
Send a message via AIM to Anne Shade
What exactly are you asking? Are you trying to lock it in low or high gear? Is that what you are talking about?
Anne Shade
Past Teams: 132, 408, 608, 832, 1002, and 2377
Unread 04-02-2003, 12:29
Dush's Avatar
#1166 (highlander)
RETraCtion------ THE moTor Is ActuAlly SlipPinG OuT OF the BraCkET
Unsung FIRST Hero
Bill Gold Bill Gold is offline
Retired -- 2006
Rookie Year: 1999
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Re: That makes two problems
I was going to say something to that effect also.
My God Dush, that's annoying.
Unread 04-02-2003, 12:35
Dush's Avatar
#1166 (highlander)
how do you eliminate the problem of the bosch drill motor slipping out of the back of the motor cradle?
Unread 04-02-2003, 12:38
Dush's Avatar
#1166 (highlander)
on the bakc of the mount, the motor part where the brusjes are, it is not pinching well in the cradle, this causes the motor to silp out..how do you fix?
Unread 04-02-2003, 13:33
Parks Parks is offline
Parks is an unknown quantity at this point
Stop the motor from Falling out
We never had this problem but we did have a problem with the drill motor being too loose in the cradle. We reorientated it such that the electrical leads are on the top and the bottom if you lie the unit flat on a table. This helped to wedge it in there. Also make sure that you securely fasten the rings that fit over the top of the unit. This should prevent accidental loss of any drill motors.
Andrew Parks
CrescentSchool Robotics
Co-Construction Head and Driver
Team 610
2002 Regional Champs
2002 Engineering Inspiration
2003 Regional Chairman's Award
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
