Go to Post Why does school have to get in the way of more important things like FIRST? When would we ever need to know about the stuff there teaching in here? - Briansmithtown [more]
Unread 04-02-2003, 12:07
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Mutiplexing additional pushbuttons
We've run out of input bits on the OI.
Anyone have a GOOD trick for multiplexing switch inputs so we can get a FEW more? I need the equivalent of either a bunch of pushbuttons, a "radio push switch" (one of N buttons lock down), or something otherwise akin to a Single-Pole N-Throw rotary switch to select at most ONE (or NONE) of something.
I'm not sure if a diode matrix is legal ("custom circuit running an input"), and I'm not sure if we WANT to have to "address" them with LED outputs even if it WERE.
I'm also not sure if using an R2R resistor ladder (or shorting out individual weighted resistors) to encode them in binary as a "pot input" would be clean enough from a debouncing perspective (we may get wrong values on some loops, but we COULD filter them).
So... What have YOU guys done in the past whenever you've run out of switch inputs to get a FEW more??? (Besides "change the design" ) Please be specific with values if you have something like a resistor trick.
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 04-02-2003, 17:05
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Two years ago, we ran into the same thing. In order to get one more switch, I wired up an LED and a switch in series to an analog input. When "on", it read one value and when off read 127. I'm not sure how legal/smart this was, but it worked two years ago.
--Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Additional hardware list archiver 2000 5 23-06-2002 22:54
Additional Dashboard Data Curtis Williams Programming 3 08-02-2002 15:25
additional materials: mylar? Frank Toussaint Off-Season Events 3 02-11-2001 16:06
additional materials Penn Robotics Off-Season Events 1 01-11-2001 23:25
Are additional pulleys "cable fasteners"? kmcclary Off-Season Events 6 26-10-2001 01:56
