Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 06-02-2003, 22:06
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Rotating Light
Now, before anyone dashes off a quick link to the first "rotating light" thread they find, does anyone know if there is a definitive answer on mounting the light? I've searched here and the official FIRST forums, but there's just too much contradiction to wade through.
My specific concern is: can the light be momentarily retracted or turned out of the way (i.e., with a spring or pneumatic). I've yet to find two similar answers to this question.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 06-02-2003, 22:07
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Umm.. Yes. This was mentioned in those threads. FIRST says its okay for that to happen for a few moments.
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 07-02-2003, 14:32
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
difficult answers...
FIRST has made it quite difficult to interpret this year (imho).
As best as I can figure it, the following covers 99% of the rules concerning the light:
You have to have the light mounted bottom side down to meet the "upright" requirement and not just in the starting position. Essentially, except when going under the bar, the light must be bottom side down. If you fall over like Beatty did last year you have to have your light keep its bottom side down both before and after the fall (perhaps by mounting it on a swivelling base for example).
You have to have at least 4 inches of the light "exposed." "Visible" is not good enough. For example, it cannot be behind clear sheet of polycarb. Exposed means exposed -- why? Because that is what FIRST wants, that's why!
You can (for brief periods of time) retract or dip the light to get under the bar.
You may not have the bar hit the light to retract or deflect it (for example, you cannot mount it on a spring that just gets deflected by the bar as the robot runs the light into the bar).
You can have the bar activate a switch that would tell the controller to retract the rotating light but you cannot have the bar itself retract the light.
In my mind it is still not clear if you can have a bar hit a lever that retracts the light, but I think not as it would run afoul of the rules against reacting against forbidden field surfaces. But... ...I could be wrong on this point.
So...
...have I got it about right?
Comments welcome.
Joe J.
P.S. A summary from FIRST would be very helpful -- if anyone from FIRST is out there reading, please take note.
Unread 09-02-2003, 15:38
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
exactly... the light can go down and up for a few seconds to get under the bar, but it has to go down/up under its own power, not by being pushed down by the bar (i.e. motor or pneumatics)
Trust, Love, and Magic
Unread 09-02-2003, 17:01
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
If you take the rules literally, you can have 1.2 seconds where your light is not visible.
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 09-02-2003, 17:14
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
The rules confuse me on this topic. What if you are a stacking team? if your stack goes above the height of your robot or the highest part of your stacking mechanism, your light will obviously be blocked from view from one direction. What happens then?
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 09-02-2003, 17:25
Natsume Natsume is offline
Natsume is an unknown quantity at this point
I have a feeling that FIRST might be a little more lenient on the rulings of this.
Last year, during the Silicon Valley Regional, they were a lenient on the rulings of a line to touch the opposite ends. No wires or lines, but meausre tape was allowed...Anyone think they'll be a little more lenient on that ruling this year?
Unread 09-02-2003, 22:46
make me care
#0555
Team Role: Student
in my limited opinion, first rules are based on the robot as it starts.... if stacking causes the light to get blocked, they won't care, because its not important... if the stacker device blocks the light without boxes, your screwed, but the boxes themselves don't matter...
its like saying the goal blocked the light from view last year, or the ramp blocked it this year... who cares... as long as the light can be seen "MOST" of the time, the odd few seconds stacking or going around the ramp won't matter (period).
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
rotating light archiver 2000 1 23-06-2002 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
