Go to Post I love you ChiefDelphi times! - Amanda Morrison [more]
Unread 07-02-2003, 04:46
Carl Owenby Carl Owenby is offline
#0654 (Maclay Robotics)
Carl Owenby is an unknown quantity at this point
Robot reset on OI doesn't work
The Robot Reset switch on our Operator Interface doesn't appear to reset the Robot Controller. The only indication that I see on the RC is the Basic Init Err LED flashes for a moment approx every 3 times whan I press the reset switch. The Search/Tx, Valid Rx and Basic Run LEDs continue to flash.
The Reset switch on the Robot Controller operates normally, all LEDs on the RC go out except for Power On.
Any ideas as to what's happening?
There are 10 kinds of people in this world; those who understand binary and those who don't.
Unread 07-02-2003, 07:23
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
The ROBOT RESET button is intended to allow remote reset of the Robot Controller’s BS2SX PBASIC
processor. The most common use for the ROBOT RESET button is to restart the BS2SX processor in
case of a programming error. The ROBOT RESET button can also be used to reset the BS2SX after a
new program has been downloaded if needed.
The ROBOT RESET button on the Operator Interface only resets the BS2SX and not the entire Robot
Controller. Using the RESET button on the Robot Controller or power cycling the Robot Controller are
the only ways to reset the entire Robot Controller.
Operator Interface Reference Guide p.18
I think that should answer your question.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
The Unnoficial Constitution - A Real Inspiration sanddrag Team Organization 6 19-09-2003 15:40
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
