Go to Post if it's likely to break, it probably will - DonRotolo [more]
Unread 07-02-2003, 15:48
LeadRiccardoT LeadRiccardoT is offline
#0849 (Wolf Pack)
LeadRiccardoT is an unknown quantity at this point
Power Terminals
Does anyone know where to find the 6AWG ring terminals?
Unread 07-02-2003, 16:17
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
can you be more specific are you talking about the ring connectors that are used to connect the leads of the battery to the battery and to connect the 6 awg wire to the fuse panel? if you are then you should be able to find them at any store with electrical connectors (IE. Radio shack, ACE Hardware, Lowes, etc) any store like that should carry them.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 07-02-2003, 16:36
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Team Role: Coach
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
If you ask for "Ring Terminals", they might look in the wrong rack and tell you that they don't have them. Most of the 6awg "ring terminals" that I've found are referred to as "Lugs". The only difference between them (as far as I can tell) are that "Lugs" do not have any insulation on them.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 08-02-2003, 09:41
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You can find these crimp ons at Radio Shack in a pinch (they are more expensive) or even at Home Depot. Any hardware store or electrical supply will have them if you need them quick. Otherwise check out Digikey.
Also, when specifying terminals you have to say the wire size and the stud (hole in the terminal) size.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-02-2003, 11:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
C&H Surplus in Pasadena, CA. (I'm not sure if they're on the web.) APEX in Sun Valley, CA. (not on the web) Possibly www.allelectronics.com
Unread 08-02-2003, 11:28
Don Reid Don Reid is offline
Don Reid will become famous soon enough
I found ring connectors for #6 wire at a local auto parts store. They were with battery cables, not with the smaller crip connectors.
Don Reid
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power supply of control system archiver 2000 5 24-06-2002 00:14
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
