Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
Unread 07-02-2003, 16:49
powercat powercat is offline
powercat is an unknown quantity at this point
comp_mode
Do I need to use the comp_mode for anything?
And how will testing at competition be done to ensure autonomous mode is obeyed and operators aren't really driving during this period ?
Code bugs happen, how will they ensure that the robot obeys ?
Just curious. I use the auton_mode to determine if autonomous or user driven.
thanks.
Unread 07-02-2003, 16:59
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Taken directly from the Default code:
Code:
  Bit 7 of the PB_mode byte (aliased as comp_mode below) indicates the status
 of the Competition Control, either Enabled or Disabled.  This indicates the
  starting and stopping of rounds at the competitions.
  Comp_mode is indicated by a solid "Disabled" LED on the Operator Interface.
  Comp_mode = 1 for Enabled, 0 for Disabled.
In other words, when comp_mode is 1, your robot runs, otherwisw it doesn't
As to the other question, you have to stand behind a line during Autonomous mode, and can only cross it to hit the kill switch. I'm sure someone will make sure noone violates the rule.
--Damian Manda
Unread 07-02-2003, 17:08
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
http://hyperrules.chiefdelphi.com/vi...php?ruleid=265 - From Update 11
For whatever reason, IFI inverted the comp_mode bit from what the comments in the source code say.
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
