Go to Post Maybe next season I want to develop and test a new metric for FRC scouting: Bumper Quality Rating (BQR). BQR-5: The platonic ideal of FRC bumpers. ... BQR-0: Moderate to heavy use of duct tape. I believe BQR would outperform OPR as a predictor of on-field robot performance. - Nate Laverdure [more]
Unread 08-02-2003, 12:17
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
Gearbox
Hey, this does not really pertain to the competion, but I have some very powerful 2500rpm 12v motors, and i need a gearbox to get them down to 100rpm. It doesn't matter if it is preassembled or just gears but any advice, suppliers, etc. would be highly apreciated. Thanks
pi is exactly 3
IM me at: zmstr265
Unread 09-02-2003, 16:05
#0321 (Robolancers)
has no one any help?
pi is exactly 3
IM me at: zmstr265
Unread 09-02-2003, 16:17
Jeff_Rice's Avatar
Jeff_Rice Jeff_Rice is offline
ElementisRegamusProelium
#1359
Jeff_Rice will become famous soon enoughJeff_Rice will become famous soon enough
Use one gear with four teeth and one with 100
or you could do 5, 25, 125.
Just do the math. Its pretty easy. There are tons of combinations I haven't mentioned.
More than likely you won't use those ratios, but you can get sprockets, chains, etc at your local bike shop.
As for gears? I'm not sure. But yes, you could use sprockets and chains instead of meshing the gears
"He said my name is Private Andrew Malone
If you're reading this then I didn't make it home
But for every dream that's shattered another one comes true
This car was once a dream of mine now it belongs to you
And though you may take her and make her your own
You'll always be riding with Private Malone" David Ball, "Private Malone"
Unread 09-02-2003, 16:25
#0321 (Robolancers)
yes, you are correct, but prehaps I was unclear in my request. i am more looking for suppliers, or actual plans for such a gearbox. Thank you though.
pi is exactly 3
IM me at: zmstr265
Unread 09-02-2003, 20:14
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Check Chapter 15 of the MSC catalog that came with your kit of parts for this year. Look under "speed reducers" and "gear drives." If you don't find what you need, at least check out the vendors listed there (Boston Gear, Perfection Gear, Browning, etc.) and follow up with them.
-dave
Y = AX^2 + B..... ehhh, whatever
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Drill gearbox clutch Joe P Technical Discussion 3 12-03-2003 13:22
Connecticut teams, gearbox needed GaelHawks230 General Forum 0 08-03-2003 13:41
drill gearbox schematic? Jeff Sharpe Technical Discussion 3 21-01-2003 00:18
