Go to Post I'm not suffering from my FIRST "addiction". I enjoy every minute of it. - Katie_UPS [more]
Unread 08-02-2003, 17:07
great_one411 great_one411 is offline
#1210 (NYACK)
great_one411 is an unknown quantity at this point
wheels
After we connected our motor and wheels correctly and put it on the floor, one of our wheels wouldn't work. HOW do we fix it!!!
Unread 08-02-2003, 17:15
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
What do you mean 'won't work'? Is it not spinning? Is it not touching the ground? Is the motor moving?
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
what exactly was the problem? was motor not turning? or was the wheel not gripping the ground?
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
what is your drive setup? are you using the supplied gearboxes from FIRST? check and see if the motors are turning. If they arent, then there is somethign wrong inside the motor if they are, follow the pieces until you see where it doesnt turn any more and that is probably the problem.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 08-02-2003, 17:33
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Rookie Year: 1999
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
If the motor is not turning, see if it's moving at all when the proper controls are activated (e.g. joystick). If it jerks/moves a tiny bit then stops, it could be a gearing/chain/belt problem. If it's not moving at all, check the speed controller, if it's LED is blinking, it's not getting a signal from the robot controller. More details would help, so we know what's connected, what's working, what's not working, then we can help you troubleshoot more.
Unread 08-02-2003, 18:24
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
Make sure there is power getting to the motor also.
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Question about wheels Randy_Ai Technical Discussion 9 24-01-2002 17:14
Skyway wheels w/o bearings ahecht Technical Discussion 4 22-01-2002 01:25
