any idea if that would be in the next version (toggle) ? and when do you expect the next version?
also, let me just personally thank you because RoboEmu has saved me SO MUCH time! Now i can work on robot software AT HOME, without any robot, and know that when i put it on the bot, it will work perfectly, the first time! THANK YOU!!! |
![]() Back on topic... I tried the timing on my windows 2000 machine, and it works fine. On the windows 98 machine, it runs too fast. Any ideas? |
--Rob |
actually, I saw the 2x too slow when i ran it in wine...but I attributed that to wine, not the program.
I agree with Steven Carmain. I am running my same program which is using the posted 38 loop count per second algorithm on emu 1.10 and 1.11 and there is a marked difference. My program runs much faster on 1.11. (Actually, under the 1.10, my program would run the 15 second loop in just under 18 seconds, anywhere between 17.6 and 17.9 seconds.)
Also, the serout from the default program I downloaded from the Innovation First site has to be adjusted by adding 4 instances of ",127" at the end of the serout command which makes the completely compliant with the comment that comes with the default code that talks about the SEROUT line. Lastly, 1.11 keeps dying when I have bad code. Also, if there is bad code and I get the standard "Would you like to quit?" and I say "No" then the file I just loaded get's locked so that I can't save it using the PBASIC editor. I have to kill RoboEmu to save the file. This is not too much of a problem when I am writing good code. ![]() ![]() |
I used the code that I posted, and it still runs 2x fast, but runs fine in 1.10. My computer is an XP.
Wow. Five days of no activity and this is already on the second page. Anyway, I'm going to try to finish up 1.11 tonight, so this is the last call for any bug reports, etc. Here's the current list:
Bugs: Strange timing issues Crashes if dividing by zero Crashes with very long lines Doesn't close file handle properly on errors Falsely gives ELSE without IF in some instances (doesn't happen in 1.10) comp_mode is backwards (I hadn't read the update from InnovationFirst at the time) Proposed features: Toggle Arrays (::shudder:: may or may not happen until next beta release) Single-step More of the DEBUG modifiers (ie BIN8, etc) Anything else? I'm going to start working on it around 8:00 tonight, so please let me know by then. As always, either post here or send me a PM/email. Last edited by rbayer : 15-02-2003 at 11:06. |
It does not detect errors with the number of initialization constants turned on not being the same as the number of things in the Serin.
This is important when you are making a timer. Thank you for making RoboEmu, rbayer. |
#10
well, for one thing, the toggle function might be nice...
but also... i noticed some differences in the way that roboEmu and the true basic stamp interpret logic statements. I'm not sure what the problem is exactly, but in the example i had, if you have more than one operator in a series like this... if [condition1] & [condition2] & [condition3] & [condition4] then ... roboEmu does this the "correct" way, where ALL conditions have to be true, but this is not the case with the stamp interpreter. i've tries many combinations of parenthesis’ with varied results, but never the way i want them. i guess i'm not sure what the problems is here, if it is roboEmu, or the stamp. Maybe i'm just have some syntax error, but i'll let you decide.. MEH |
#11
The & is not the correct way to do it as it is meant for bitwise anding (like C's &). Use the keyword AND instead as it is like C's &&.
Hmmm... I'll see what I can do to make RoboEmu more correctly incorrect. Anybody have anything else? --Rob |
#12
lol, THAT would fix it! thankyou!
by the way, what does the '&' operator do then? |
#13
Code:
110111001 & 010101011 ---------------- 010101001 110111001 | 010101011 ---------------- 110111011 ~110111001 ---------------- 001000110 Any other RoboEmu comments from anyone? I'm off to robotics in a few minutes, but should still be able to work on stuff later tonight. --Rob |
#14
another thing that would be nice is to have indicators for port feedback lights...such as "out12, out13, etc"
just an idea eric |
#15
Gosub Depth Reporting
RoboEmu properly reports if the gosub depth is too great. However, if you fix the problem in your code, save it and have RoboEmu reload it, the depth is still reported as incorrect. RoboEmu must be exited and restarted.
| Obscure PBASIC for RoboEmu | rbayer | Programming | 1 | 28-03-2003 23:57 |
| Making RoboEmu 1.09 work | rbayer | Programming | 2 | 14-01-2003 00:49 |
| RoboEmu 1.08 released | rbayer | Programming | 9 | 26-12-2002 22:31 |
| RoboEmu 1.07 | rbayer | Programming | 3 | 08-12-2002 18:28 |
| RoboEmu for Linux (PBASIC emulator) | rbayer | Programming | 5 | 21-11-2002 21:08 |
