Go to Post Maybe Dean Kamen can appear in Levi's advertising? - David Brinza [more]
Unread 09-02-2003, 14:21
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
Yaw Rate Sensor to 90 degrees?
OK, I give up. I never claimed to be a programmer (I live in an analog world!) But I've been trying to figure out how to integrate the rotational velocity output of the gyro to degrees of heading information. All I really need to do is determine when I have completed a 90 degree turn, either to the right or the left.
I understand how the how the gyro works, how it interfaces to the analog port, and how the resulting bit count (0-254) relates to rotational velocity. I can even figure out how to sample that each loop cycle time (26 msec.) and accumulate delta_heading changes. What I can't figure out is how to do it WITHOUT FLOATING POINT MATH!
I know there must be a way to scale the gyro output and manipulate it with integer math to figure out when it has rotated 90 degrees, but I just have no experience with integer math.
Please, someone, how about a hint of the pbasic code required. Someone must have done this already?
Thanks,
Bruce C.
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
