Go to Post Are you prepared to be a team member? - JaneYoung [more]
Unread 14-01-2002, 15:45
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Question goals
if you throw the ball into the goal and it bounces back within the goal and it gets stuck between the PVC pipes, does it count?
There will be goal(s)! Dr.Bot Rumor Mill 48 22-12-2002 09:03
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
the size of the pipe on the goals archiver 2001 2 24-06-2002 00:07
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
