There are two connectors on the end of the pressure switch marked C and NC. How do these get wired into the controller so that they can control the pump pressure? Any help appreciated.
Team 1163 The Trojan Horses |
C (for Common) and NC (for normally closed) are the two sides of the switch inside. At low pressure, the switch is closed.
Connect the terminals to a ground pin on the DB-25 connector, and to an appropriate digital input pin (it doesn't matter which of C or NC goes to which of ground or input). In tyour program, the closed swith appears as a 1, changing to a 0 when the pressure gets near 115 psi. It stays open (0) until the pressure drops to is it 85 psi, then goes to 1, again. |
It actually doesn't matter which way you do the NC and C, from what i've tested, because it's a digital switch anyways.
That sounds great. Thanks for the assistance. Team 1163 |
Don't Forget
You will need to make a cable that connects into the Digital Input on the controller. We have ours connecting to pins 2 and 6 as labled in the Manual on page 13.
Our team is using this switch, and I have a question...
Do we HAVE to wire it up to the RC thrugh the digital inputs or can we just wire it in series with the compresser. The latter would be 1000 times easer, safer, and save about 5 feet of wire. I just have it: (12v+) --> (COMMON) (NC) --> (COMPRESSER +) (COMPRESSER -) --> (12v GND) and that seems to work fine, it shuts off at 115 psi and there is no programing required. Did I make a big mistake or is this acceptable? thanks in advance - Jacob |
whoops
If anyone wires the pressure switch to a digital input, they will simply be disqualified. FIRST specifically states in the checklist that the switch must be wired through a RELAY. I guess i'm going to have to make some modifications next week.
#10
http://www2.usfirst.org/2003comp/2003inspechecklist.pdf
#38 Pressure switch cannot be wired in series with the pump. It must go through a spike relay. |
#12
The _compressor_ must go through a spike. There are reasons why everything you _can_ do is not something you _should_ do. Maybe the folks at IFI have made sure that First team members are safe from their mistakes, but just because you got away with it, doesn't end it. The Spike relay is two circuits in one package. The input is an LED which needs the appropriate current and (thus) the appropriate voltage and polarity. The pressure switch has no source of 5 V, which is what the Spike needs on its input. If you wired the input, via the pressure switch to +12V, which is the only voltage available (except in your electronics) you could a) apply overcurrent and blow out the LED input to the Spike, or b) apply high reverse voltage and blow out the LED input to the Spike, thus ruining the Spike. ![]() If you wire the switch to the RC digital input, and put the compressor-controlling Spike on an appropriate output, the Spike is supplied with the design-nominal voltage/current level signal, and the compressor can be officially turned off before and after the match. ![]() The advantages to doing it this way include not being told to rewire and get re-inspected, and not having erratic (or no) operation of the Spike. Hope this helps. ![]() Last edited by Lloyd Burns : 03-03-2003 at 11:17 PM. |
| pressure switch | Antonio | Pneumatics | 10 | 01-31-2003 03:52 AM |
| Auto Air Pump Code | zorro | Programming | 25 | 01-05-2003 04:50 PM |
| pressure sensors | archiver | 2001 | 0 | 06-24-2002 02:15 AM |
| Need help with 255 Variable | Joseph F | Programming | 18 | 02-26-2002 02:49 PM |
| Pneumatic pressure sensor | Curtis Williams | Pneumatics | 3 | 02-04-2002 08:09 PM |
