Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 12-02-2003, 17:01
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Light Tracer + Bump Map?
We are experiencing weird artifacting problems when using Light Tracer with tiling bump maps (like carpet, and other large flat surfaces) It seems that supersampling and texture filtering does not work correctly when rendering bump mapped surface with light tracer. Instead of a smooth, perspectively blending pattern, the renderer produces sharp black lines where the bump-mapped indents should be. ( You can see a mild example of such artifacting on one of our gallery screenshots at www.eccentrix.com/members/z80180/index.htm - look at the last two robot pictures) Inecreasing quality settings didnt help much.
Have anyone else experienced this or knows how to fix the problem?
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
light visibility Erinn888 General Forum 30 17-02-2003 15:56
About the light that need to be seen from four side archiver 2000 3 23-06-2002 23:01
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
