Go to Post First check for any bind in the transmissions, especially chain. Next, check to see if the motors are O.K. Use code as a last resort. - Paul Copioli [more]
Unread 12-02-2003, 20:00
J-Weazy J-Weazy is offline
J-Weazy is an unknown quantity at this point
Thumbs down Our Pressure Switch Sizucks (<--Sucks)
All right everyone, our team is pretty new and we're having a few problems with our pneumatics. We've got everything set up perfectly. Our tanks max out at 120 and our regulators read 60, so everything is working fine. The only problem is our pressure switch won't activate. We let the tanks get to between 120 and 130, but nothing happens.
The Pressure switch is connected to a regular 25 port cable, using pins 2 and 6, which are connected to the C and NC connections on the switch, but it's yet to work. We've even switched pins 2 and 6 on the NC and C connectors as well as switched the cable from the Digital Input to the Analog Input, but it doesn't work for either.
I was wondering if any of you could lend us any help with this problem. Thanks a lot.
Sincerly,
J-Weazy
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
