Go to Post Funny, I came to robotics for the robot, but find I stay for the people. - Mr. Pockets [more]
Unread 14-02-2003, 14:05
Michael Long's Avatar
Michael Long Michael Long is offline
FRC #1024 (Kill-a-bytes)
Rookie Year: 1999
Michael Long is on a distinguished road
Send a message via AIM to Michael Long Send a message via Yahoo to Michael Long
Question soleniod plugs
the holes that the solenoids release air from need to be covered so nothing gets in, but air can get out.. any suggestions??
Never Argue with an idiot...
They will drag you down to their level...
and beat you with experience...
Unread 14-02-2003, 14:23
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
If I understand this correctly, you're afraid of "backdriving" a pneumatic actuator, when it's been previously energized?
To my knowledge, you don't have to connect the exhaust ports to anything, including a one-way flow valve (I'm not too learned in the terminology, quite yet).
And, if it didn't come in the kit, and wasn't one of the three custom actuators your team ordered, you can't use it in the pneumatic system for your robot.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 14-02-2003, 15:02
Rookie Year: 1999
all i am talking about is some kind of plug used to let air out and not let stuff like metal shavings in... that could be bad... for example the technocats use plugs that look like airator stones from a fish tank but on screws.. (team 47 ,where do you get them?)
Unread 14-02-2003, 15:14
I can't seem to find what you're referring to, in the TechnoKats' pictures.
If you're going to be generating metal shavings during competition, you have bigger things to worry about. If you're just trying to keep things clean and safe while you're working on the robot, cover them with shoptowels, someone's shirt, or whatever else you might have, on hand.
Unread 14-02-2003, 16:14
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You shouldn't need to cover the holes. If a shaving get's in, in most likely won't go into your cylinder, if it does.. it still should be traumatic.
If you are worried about stuff coming in, take a normal plug (for putting hose into), stick it in there. Air will still be able to travel out easily and nothing will come in. You don't need a tube either.
If you are still paranoid, stick a tube in it and run it to a shielded place. Or better yet, just shield your solenoid. As Foto said, shop rag, shirt, whatever. When it comes competition time, throw something else over it, or wire-tie the shop rag on.
Unread 21-02-2003, 21:20
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
One-way flow is permitted by a "check valve", akin to elecronics' diode.
The 'aerator' of metal balls that looks like an airstone is sometimes called a "muffler", since by increasing the area through which the exhaust flows, and by calming its turbulence, the lous "Pshhh!" is quietened.
suggetion - do your machining on another planet, so you get no shavings near electronics or pneumatics.
question....to you all. archiver 2000 21 23-06-2002 22:13
