Go to Post Anyone know anything about a missing plastic flamingo from NASA HQ? I should mention before you answer that tampering with federal property, even if it's weird stuff from (Dave's) office, is punishable by painful delivery of ChiefDelphi negative rep points. - Rich Kressly [more]
Unread 14-02-2003, 16:53
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Yaw rate sensor pin-out
I can't find the datasheet for the yaw sensor, can someone please tell me which is vdc, common, and output? Looking at the connector with the bolt holes down, the sticker on the left.
thanks,
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
