Go to Post Weight down low is a good thing. Weight up high is not. - s_forbes [more]
Unread 15-02-2003, 11:07
LizJJury
Posts: n/a
Arrow tga number2
I found this in team update number 13
where it talks about the Targ0000.tga
I thought it was just to render things faster but the other peoples ib the team think that we have to keep it with tga...
What do we do?????????
Unread 15-02-2003, 20:01
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
Re: tga number2
Ok, what autodesk is saying as a tip is actually what already happens automatically when you network render or just render multiple frames at a time.
Basically the tip means............... Save your files as this filename0000.type of format (the 0000 should be your frame number that you are starting out on (remember you start on frame 0 not 1)) So for instance when I go to render my 909 files at 30.03 fps I save it as Team93animation0000.jpg the program will automatically rename the files in chronological order like Team93animation0001.jpg Team93animation0002.jpg ect...
The file format does not matter but different compressions take different amount of time to render and take up different amount of space.
If you need more clarification on this pm me.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
tga files for animation LizJJury General Forum 1 15-02-2003 16:36
