Go to Post We were asked to help change a culture. If the solution was simple FIRST would have given more specific guidelines on how to do this. It is our job as teams to find unique and creative ways to help fulfill the request from FIRST. - tim-tim [more]
Unread 16-02-2003, 14:02
LeadRiccardoT LeadRiccardoT is offline
#0849 (Wolf Pack)
LeadRiccardoT is an unknown quantity at this point
3 way toggle switch programming
i need to know what the 3 way toggle switch sends to the operator interface thru ports 2 and 4. Can anybody help me?
thank you
Unread 16-02-2003, 14:19
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
It really depends on how you wired it into the OI. Each wire that goes back to a digital input will be represented by a different variable in the program. If you could post more details on your specific setup, I could give you a few more details.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 16-02-2003, 14:21
#0849 (Wolf Pack)
We are using a 3-way toggle switch to control a speed controller (window motor). We would have used relays, but we ran out. We just want foward, reverse, and off. I'll check how it is wired to he joystick port. Thanks for the help.
Unread 17-02-2003, 02:02
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
a 3 way toggle is just like having 2 switches in 1, except they both can't be on at once. Wire it up with common in the middle, and a live wire on each end, look at the OI controller, and follow the pin out guide. Up will be on 1 of the OI inputs, and down will be another...
Using a switch before autonomous operation KZos550 Programming 11 04-02-2003 19:12
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
1 or 2 phase switch archiver 2001 0 24-06-2002 00:48
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
