Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 16-02-2003, 14:29
Tracy Tracy is offline
Tracy is an unknown quantity at this point
Visibility of Robot Controller and Reset Button
In the rules, it says the Robot Controller must be visible and the reset button available. Exactly how visible and available must the Robot Controller and rest button be?
Unread 17-02-2003, 07:36
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
The judges will look at your controler at inpection, before and during the match. They have to be able to see the lights and if you have problems they need to see it to help digenosie the problem. Last year and previous years you had to hit the reset button on the RC evey time you downloaded a new program but this year is resets automaticly. I personally this year have noticed that some times the RC totally locks up and you have to hit the reset button to get it working again, though cycling power on the whole robot would also do the trick.
So where should the RC get mounted? I would say visable and accesable but not in the open. If it breaks that is $565 to replace and I don't know about you but our team doesn't have that much money.
Hope that helps.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Robot Controller Reset Problems. Joe P Electrical 8 26-04-2003 11:56
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Robot reset on OI doesn't work Carl Owenby General Forum 1 07-02-2003 07:23
Operator Interface is crazee !!! HELP punarhero Programming 30 17-07-2002 14:23
Fingers and Robot Controller archiver 2001 4 23-06-2002 23:54
