Go to Post According to my father the hint should be released sometime next week, but he's never been the most trustworthy source of info.... - Lil' Lavery [more]
Unread 16-02-2003, 15:02
maDGag maDGag is offline
maDGag is an unknown quantity at this point
subs/functions
can i pass stuff to subs ?
are there functions in PBASIC
i suppose global vars modified in sub works, but it's messy
Unread 16-02-2003, 16:33
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
there are no functions in pbasic. The closest you have is subroutines accessed by gosub. You can not pass parameters to subroutines and so, you must use global variables.
If you wanted to get fancy, you could use part of the scratchpad memory as a stack, and push function parameters onto it just like a c compiler does, but you are asking for trouble, and it would take time.
Unread 16-02-2003, 23:27
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Subroutines work just like regular code. If you go into a subroutine, it will flow straight from the code previous to the gosub command right into the subroutine. The only thing, I believe, that you cannot do is continue if statements into the subroutine. Any variables you have in that bank will still be present and any constants will also be accessible.
Subroutines are commonly used to share equations among multiple parts of the code.
I'm not sure what exactly you are asking. Maybe you could rephrase your question.
I'm not sure how you find it 'messy'.
Programmer
Team#857
Superior Roboworks
WildStang Alum
