Go to Post ....a red-light-of-death. - Kevin Watson [more]
Unread 16-02-2003, 20:30
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Bad 40A Breaker
Our robot was veering to the left when climbing the ramp. The right side drive stopped working about 2/3 up, resulting an an unplanned U-turn followed by a speedy return to the carpet, after which normal control returned.
Our drivetrain uses two Bosch drill motors, pins removed, shifter ring internally locked in low gear with a spacer we made. The second reduction stage is the 2:1 helical gear set that came in the kit. Our front drive wheels are 9" pneumatics, and we use two 80mm omni-wheels as rear casters.
We spent quite a while checking and changing elements of our drivetrain, trying to isolate the problem.
We checked to be sure the friction was the same on both sides, by manually rotating the wheels and then by free-rolling the robot down the ramp with the power off. No difference observed between right and left, and the 'bot rolled straight down the ramp and continued across the carpet several feet.
We removed and replaced the right side motor controller, with no effect. Then we removed and replaced the right side motor (leaving the gearbox in place), again with no effect.
We checked and rechecked our wiring, our software, our custom electronics -- all with no effect.
Finally we tried swapping the right and left 40A breakers. That made the 'bot veer right instead of left.
Aha!
So we replaced the offending 40A breaker and have not seen the problem since.
Apparently some 40A breakers are more sensitive than others.
Has anyone else seen something like this?
Richard Wallace
since 2003
Unread 17-02-2003, 15:49
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
as of yet ours are working fine. though we have been draining our batteries pretty fast.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-02-2003, 21:33
Rookie Year: 1996
More on the Bad 40A Breaker
I got some time to test the bad breaker today. Connected it to a regulated laboratory power supply, Sorensen model DCS 20-150, in regulated current mode. Increased the current slowly and saw nothing unexpected until it reached about 30A. At that point its started switching on and off very rapidly. This is consistent with the behavior observed when the bad relay was in our robot.
Seems that we damaged it somehow, or maybe it was bad from the start.
Again, has anyone seen similar 40A breaker behavior?
Richard Wallace
since 2003
Unread 18-02-2003, 21:42
oracle_nick oracle_nick is offline
oracle_nick is an unknown quantity at this point
Send a message via Yahoo to oracle_nick
We (team 1103) had the same problem with a 40a breaker. Lucky enough for us we were able to get rid of it and not have any problems.
40A Breakers popping when using CIMs galewind Electrical 9 13-02-2003 10:30
Keyang Motor Thermal breaker. archiver 2000 1 24-06-2002 00:24
Pump Problems... archiver 2001 2 23-06-2002 23:58
60 amp breaker Anne Lam Technical Discussion 10 10-01-2002 15:13
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
