Go to Post You think you are building robots, but you are really building yourselves. - sanddrag [more]
Unread 17-02-2003, 01:04
etoleb etoleb is offline
#0891 (Neverending Chaos)
etoleb is an unknown quantity at this point
Send a message via AIM to etoleb
Wall 'o Boxes
Although at first, I thought the wall of boxes would decide the winner for 90% of the matches, I'm beginning to change my mind. Even though a team can acquire 30+ boxes on their side, there's still a 5'3" neutral zone to consider, and any robot with a working drive train could "neutralize" the boxes while the opponent tries to stack (or attack the stack while the opponent defends the boxes). There is also the possibility of stealing boxes (assuming there is no problem crossing the ramp).
However, I've noticed several threads from scrimmages suggesting that stacking was generally unsuccessful. Thus I begin to wonder if the total number of boxes on an alliance's side had a major impact on the result of the matches. My impression from the other threads is that it was very difficult to perform any task with 3 other robots on the field...
So, I suppose the real purpose to this thread is what does everyone else see in this mess? To me, it seems like moving boxes after autonomous mode is more important that getting them in the beginning.
Greg
Team 891
Unread 17-02-2003, 01:25
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
at media day here in alabama, there were 5 or 6 teams there, and every match was won in the first 15 seconds, so i am still saying that is the case.
Unread 19-02-2003, 17:17
Were the matches won because some robots were more complete than others? Or was it because teams were able to keep their bins in scoring position?
Greg
Team 891
Unread 27-02-2003, 19:12
soezgg soezgg is offline
Senior Member
AKA: Harry Miller
#0639 (The Rude Awakening)
soezgg can only hope to improve
Send a message via AIM to soezgg Send a message via Yahoo to soezgg
from what people are saying, the main wall will be the winner.
i hope that is not the case, as my team and many others have focused on stacking.
with stacking it is POSSIBLE for a team to win with 1/4 the amount of bins.
being a koth bot may be very successful, but stacking is just crazy and fun
i believe that the most successful teams will consist of one stacker and one koth bot.
anyway
Unread 27-02-2003, 19:26
MikeDubreuil's Avatar
MikeDubreuil MikeDubreuil is offline
Carpe diem
FRC #0125 (Nu-Trons)
Rookie Year: 1999
MikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond reputeMikeDubreuil has a reputation beyond repute
Send a message via AIM to MikeDubreuil
It really depends on who your opponents are...
If you hit the wall onto your side first and then you are able to hold the ramp, not allowing anything through. You will most likely win. However, you will not win if your opponents are stackers with the capability of dumping several boxes at a time over the bar. Then they simply push the boxes into their scoring zone and you lose.
If you do knock the stack onto your side it is important to push the boxes down the ramp so they will be in scoring position. The only benifet for leaving them on the ramp is to make it more difficult for a robot to come up at you.
Lets pretend your opponents are two tanks. Even if you have the stack in your scoring zone you better start stacking or you won't win. Your opponents will be able to dominate the ramp and get their 50 points. Granted, with a multiplier of 2 you will win. But what if one tank comes down and manhandles your stacking robots. Your opponent would end the match with 25 and you will have many bins in scoring position and hopefully win.
The more you run the numbers the more you see that the final alliances will comprise of a tank and a stacker. A very exciting game indeed. See everyone next week in Manchester!
EDIT______________
This is the first year where I think we might see rookies come up big in the finals.
Unread 27-02-2003, 19:58
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Yes, the stack does seem like it will win games.
However, in the videos I've seen, that is because the team who did not get the stack to their side did not have any good stackers... With a good stacker, you should be able to win with a small percentage of the boxes. It really just depends.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 27-02-2003, 20:00
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Are you saying every stacker in every scrimage in the country is a "bad" stacker? You say it takes a "good" stacker to effectively do it, yet, from what I've heard... NO ONE stacked a box on top of another, at any of the scrimages...
How can this be?
Are there NO good stacking bots?
/me can't wait for BAE NH to see how this game really plays out.
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
Unread 27-02-2003, 20:07
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Rookie Year: 1999
Madison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond reputeMadison has a reputation beyond repute
How can this be?
Furthermore, if there are robots that can move bins in great quantity, they stand a very good chance of tipping the balance of the game.
Stacking, while it can be an important aspect of victory, isn't necessary. I wish we would've seen this element of strategy early on, but we're taking steps to rectify our oversight. I hope other people are doing the same.
--Madison--
...down at the Ozdust!
Like a grand and miraculous spaceship, our planet has sailed through the universe of time. And for a brief moment, we have been among its many passengers.
Unread 27-02-2003, 20:18
Yan Wang's Avatar
Ithaca is Gorges
AKA: John Wayne
What i said was I have not yet seen a good stacker in the scrimmage videos that I have seen... read that carefully and don't make any assumptions.
Fact is, not so many teams went to scrimmages and most that did had not all complete robots. I expect things to be much better as the regionals progress. A stackers' game is still a wild card in this year's game.
Unread 27-02-2003, 22:26
MBurr-Mecum MBurr-Mecum is offline
#0571 (Paragon)
MBurr-Mecum is an unknown quantity at this point
Send a message via AIM to MBurr-Mecum
We actually did stack one box on another two at the UTC scrimmage, but only once. We almost got three on top of the two, but the top two toppled as we were stacking them.
Unread 27-02-2003, 22:29
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
We can usually do a lot better than that, but we couldn't actually get our robot to turn at the scrimmage.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 27-02-2003, 23:05
How much ramming and abuse did the stacking robots take during the scrimages while trying to stack?
(Also, are any of the scrimage videos posted on the net?)
Greg
Who am I?
I'm that crazy guy with the duct tape tophat.
Neverending Chaos
Team 891
Annapolis '03 10th seed; Quaterfinalists (special thanks to teams 484 and 486)
Nationals '03
Unread 27-02-2003, 23:39
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
About moving boxes quickly, our robot is a launching bot (and yes, it does launch) but we don"t launch very far. Our current plan is to drag boxes behind us and go halfway under the bar, then launch the boxes over the bar into our scoring sone. We can also stack boxes (only 2 high, but multipliers are useful). Also, as I saw in a couple of scrimmages, the king of the hill bots can be repetatively rammed until a bit of their bot touches the mesh, so they"re worthless, but they still prevent people from moving boxes over the ramp. I think the most useful robots will be the ones that can get boxes over the bar somehow and can stack a bit and protect their stacks.
Unread 27-02-2003, 23:57
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
If you hit the wall and knock 29 boxes into your zone you have 2 advantages. 29 extra boxes and control of the ramp. The opposing team has to 1) remove boxes from your zone 2) get boxes into there zone 3) secure the ramp. The team who hit the wall first just has to defend. The opping team literally has to fight an uphill battle.
Saying that teams didn't stack well because bots were incomplete and drivers hadn't practiced yet is just copping out. The teams who ramp-domed and knocked down the walls first had the same amount of time to build/practice. This year stacking was more complex than ever, maybe to hard.
I'm going to base the following figuring alliances constructed for finals which include a ramp-dom and 2 low-riding stackers, (random bots in qualifying doesn't matter in the end)...
Scenario 1: Blue RampDom, Stacker vs. Red RampDom, Stacker
Auto: Blue rampdom hits the wall knocks it down lowers wings.
Blue stacker clears human player boxes.
Red rampdom is to slow to hit the wall.
Red stacker clears human player
Human: Blue ramp-dom fends of red ramp-dom. Red ramp-dom fights for hill or clears boxes. Red stacker try to move boxes over bar then stack. Blue stacker holds red stacker at the alley.
End: Blue gets 25 + any missed boxes.
Red gets little to none.
Scenario 2: Blue RampDom, Stacker vs. Red 2 stackers(there
rampdom was useless against blues last match).
Blue stackers clears human player boxes.
Red stacker heads to wall.
Red stacker clears human player.
Human: Blue rampdom holds ramp. Red stackers then clear the boxes out of blue zone and try to move them over the bar onto there side. Then they go under the bar and try to stack those boxes on there side. Blue stacker holds red stacker at the alley. A red bot could try to dislodge the ramp-dom but chances are they'd just waste there time.
In either scenario the team that loses the wall has a distinct disadvantage. They have to much to do in to little time. With the reports of how slow/difficult it is to stack i'd say theres little hope.
  #15   Spotlight this post!
Unread 28-02-2003, 16:49
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I see a few things missing from this thread:
1) The neutral zone (i know this was mentioned but not enough). Who cares about the ramp if you can go under the bar? Expecially stackers that go under the bar. Make your stack (probably 6 high will end up being a good stack). Try and defend that stack. If you lose it and dont have enough time to build another one, start getting nasty. Go under the bar and push opponent bins into the neut zone. Knock their stacks down.
My problem is with the destructive attitude of king of the hill bots. A game with no stacks is a low scoreing match. This is the first time something like this has been in a FIRST game since i've been involved. Last year there was no easy way to destroy a high scoreing game nearly as fast as there is this year.
2) The wall doesnt go only one way. We are talking about robots acting autonomous. They have problems correcting for mistakes (if any ability to at all) are clumsy, and generally not effective. I don't see a robot going up the ramp and preventing all robots from getting by with bins. I suspect the bins to go pretty much 50/50 every match.
3) A tank bot is not neccissarily more powerful then a stacking robot. You catorize stackers as weak... almost all FIRST robots are friction limited. Stackers can gain a 10 - 20 lb weight advnatage easy; possibly upwards of 40lbs. Assuming your talking about robots with tracks, they do worry me (wheeled robots can't gain a sufficient advantage over other wheeled robots).
I know this doesn't describe all tracked robots, but in general they tend to be slower and less manuverable then wheeled ones. They have an advantage only on the carpet, no advantage on the HDPE.
4) I dont see how you can expect to hold the HDPE. You have less traction then robots coming up the mesh AND your being acted on at an unfavorable angle. Think about it.
Just my thoughts
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Dimensions of the kit boxes Jean McAuliffe General Forum 2 24-06-2003 00:40
breaking boxes illumanat'i Rules/Strategy 6 19-01-2003 15:44
question on launching boxes 2PI4Julia Rules/Strategy 4 18-01-2003 10:17
plastic boxes Suzy General Forum 6 12-01-2003 03:27
You can't see through an untouched starting wall of boxes Digo General Forum 31 11-01-2003 12:01
