Exactly how do they plan on turning the mode on? Thru the competition port or what? I was just wondering so I can finish my code.
Sorry to say this is about the 100th redundant question on this,
Yes it is through the competition pert same as disable of the robot From Innovation First Programming Manual Autonomous Mode Bit 6 of the PB_mode byte (aliased as auton_mode below) indicates the status of the Autonomous Mode, either Autonomous or Normal. This indicates when the robot must run on its own programming. When in Autonomous Mode, all OI analog inputs are set to 127 and all OI switch inputs are set to 0 (zero). Auton_mode is indicated by a blinking "Disabled" LED on the Operator Interface. Auton_mode = 1 for Autonomous, 0 for Normal. Autonomous Mode can be turned ON by setting the RC to Team 0 (zero) and power cycling the RC unit. Please search the Forum before posting |
| Programming Autonomous mode | Jared Stofflett | Programming | 3 | 11-11-2003 09:32 AM |
| autonomous mode problem on field | Chris_C | Programming | 17 | 03-26-2003 07:11 PM |
| autonomous mode timer | Don | Programming | 6 | 02-09-2003 10:16 PM |
| autonomous mode | Stephanie | Programming | 2 | 01-25-2003 07:57 PM |
| autonomous mode? | bigwalt | Technical Discussion | 1 | 01-21-2003 01:14 AM |
