Go to Post The most amazing and inspiring character I've met in FIRST, Wayne [Cokeley] has definately shown me the character of a true leader. - Bharat Nain [more]
Unread 17-02-2003, 19:17
nick_champ_2 nick_champ_2 is offline
AKA: Nick Reed
FRC #2902 (Nyack)
nick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the roughnick_champ_2 is a jewel in the rough
Send a message via Yahoo to nick_champ_2
pneumatic wiring
how do you wireall of the pneumatics
Unread 17-02-2003, 21:20
ark_1230's Avatar
ark_1230 ark_1230 is offline
What the Random?
AKA: Andrew
FRC #3138 (Dayton Innovators)
ark_1230 is an unknown quantity at this point
First off, you need to be more specific, but I hope this helps.
The pnuematic pump and the solonoids will need to be powered through Spikes. The pump can only be on when the pressure switch is off (open). This is done in the programming.
The info about the pnuematic parts are in the pnuematics manual: http://www2.usfirst.org/2003comp/pne...anual_2003.pdf
The info about wiring the spikes is at: http://www.innovationfirst.com/FIRST...sersManual.pdf
Andrew Kraemer
Team 979
Dayton Dominators
Unread 18-02-2003, 08:16
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
RTFM then post specific questions...
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 23-02-2003, 01:21
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Question Relay and code for pump control
[quote]Originally posted by ark_1230
[b]First off, you need to be more specific, but I hope this helps.
The pneumatic pump and the solenoids will need to be powered through Spikes. The pump can only be on when the pressure switch is off (open). This is done in the programming.
A bit more specific question:
Can someone direct me to an information source for which relay to use to control the pump and is there code already in the default program to control it's operation?
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
pneumatic wiring nick_champ_2 Electrical 0 17-02-2003 18:28
Can you stop a pneumatic pump at half shaft mjt902 Pneumatics 16 06-02-2003 11:58
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
How can i mount a pneumatic piston to a pvc pipe!?!?! archiver 2001 4 24-06-2002 01:11
wiring. archiver 2001 1 24-06-2002 00:07
