Go to Post My brain is about as full as the ChiefDelphi servers have been lately with all the info from the past few days jammed in there. - Elgin Clock [more]
Unread 17-02-2003, 23:59
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
Question Pressure Switch to Relay?
The other posts about the pressure swithes didn't really clear up how the heck you hook up the pressue switch to a relay. I think I understand how to ground the pressure switch, but how do I hook the other end to a relay? What I assume is that you ground the switch to a fuse box, but how the other end is hooked up to a relay, I don't get it. Unless you hook up the whole thing to a spike... that would solve the relay problem. I just don't know! Please help!
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
Unread 18-02-2003, 00:13
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Like the riddle about how to get down from a camel.... you don't, you get it from a duck!
In this case, you wire both terminals of the switch to the RC, on the digital input connector, and have the RC turn on a relay when the (NC) thing is open:
relay2_fwd = 1-pswitch
you may use higher level constructs like NOT or ~, but this gets the job done without worry.
For the above example, pswitch is an alias you would make in your programming for the input; say you use sw3 - you'd say "pswitch VAR rc_sw3". Let's also say you have your compressor connected to the M- (Black wire) and M+ (Red wire) terminals of a Spike, and you plug that Spike's "PWM" cable into the relay connector two.
Unread 18-02-2003, 00:17
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
I see. So it's grounded to a fuse box like I said and it's connected to the positive port on the Robot Controller. And from there, you program the controler to shut off a relay when it detects the pressure switch opening.
-Jeremy Egger
Unread 18-02-2003, 00:29
Rookie Year: 1997
The switch goes to ground in the digital port, and to one of the switch inputs.
The Spike can only be turned on via its "PWM" cable input, which applies a current to a LED in the spike. The ground for this is the black wire terminal. Just connect the Spike to the RC output - don't wire it to the pressure switch.
The compressor's wires go to the Spike. The Spike needs power from 12V to run itself and its LED. It, not the compressor, should be taken to a breaker and a ground terminal.
Unread 18-02-2003, 00:59
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
Ok, how 'bout you and me grab a beer and sit down at a table so you can depict your description on paper. The digital inputs, aren't those on the side of the RC with all those blank connector pins sticking out with the adapter over the controller? If so, which of those are pins 6 and 2?
-Jeremy Egger
Unread 18-02-2003, 08:24
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
look in the first manual in the electrical section of the robot guide. There is page with sample ways to hook up different sensors to the digital inputs and analog inputs...even has pretty pictures....use this for a reference for how to hook this up.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
