Go to Post As long as the competition gets the attention of someone and drags them in, it doesn't matter how they get there. - Andy Grady [more]
Unread 19-02-2003, 12:54
authgeek1218's Avatar
authgeek1218 authgeek1218 is offline
Design/Programming Geek
#1218 (CHABots)
authgeek1218 is an unknown quantity at this point
Send a message via AIM to authgeek1218
One final fairly massive problem with the code...
In short, our auton_mode is not being set to 1.
We've tried setting the competition port on pins 5 and 8. The controller flashes 'disabled' but auton_mode isn't set to 1.
We've tried setting our team number to 0. Same result.
We have set our auton_mode variable to 1 and our programs do run from there.
Code:
auton_mode		VAR PB_mode.bit6
^This is defined.
I've tried using the variable PB_mode.bit6 instead of auton_mode and this also does not work.
Is their any chance we got a bad OI that doesn't set the bit to 1 when auton mode is on? Something like that? Any help is really appreciated.
-Nick 1218
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
