Go to Post "Recycle Rush? What's that, some sort of charity marathon?" - Chak [more]
Unread 19-02-2003, 18:31
manodrum manodrum is offline
manodrum is an unknown quantity at this point
Arrow loops inside of subs???
hi, i have written a little code that will fire our pistons for approx. 3 seconds when one of the joystick buttons is pushed, so I wrote an if statement after the SERIN that
"if p2_sw_trig = 1 then GOSUB FIRE3"
that works and sends it to my sub code which looks like this:
FIRE3:
relay1_fwd = 1
MyCounter VAR byte
StepSize VAR byte
MyCounter = 1
FOR MyCounter = 1 TO 3001 STEP StepSize
StepSize = delta_t * 25
NEXT
relay1_fwd = 0
RETURN
but once i push the trigger, i get a basic run error, but, when i take away the FOR...NEXT statements, everything works, what's up with this? can i not do loops inside of subs? thanks a lot
Stephen
Unread 19-02-2003, 18:34
Joel J's Avatar
Joel J Joel J is offline
do you..
Rookie Year: 2000
Joel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond reputeJoel J has a reputation beyond repute
Re: loops inside of subs???
FIRE3:
relay1_fwd = 1
MyCounter VAR byte
StepSize VAR byte
MyCounter = 1
NEXT
relay1_fwd = 0
RETURN
Stephen
MyCounter is declared as a byte. A byte can store a number no larger than 254. After that it loops around to a negative number (an illusion).
Joel Johnson
Division By Zero (229) Alumni, 2003-2007
RAGE (173) Alumni, 1999-2003
Unread 19-02-2003, 19:59
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Re: Re: loops inside of subs???
While true, that is not the problem here. The problem is that the controllers need a SEROUT at least once every 125ms (that's once every five normal loops) in order to function properly. During your 3000-loop for structure, no data is sent or received from the rest of the RC causing it to die miserably. You need to find some way of putting a SEROUT in there somewhere.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 19-02-2003, 20:03
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Unfortunately this is not the case. It can hold a number between 0 and 255 (256 values). If you have 255 and add one to it you will get 0. When you add 1 to 1 in binary you get 10. The 0 appears and the 1 is carried over to the next slot. So when you have 11111111 and you add 1 to it all 8 values turn to 0 and the 1 is carried over into the next available space. In this case there is no space left so it is simply dropped leaving you with 00000000.
[edit]As previously stated, MyCounter is a byte which can never reach 3001. As hard as the processor tries, it can never continuously add numbers to a byte and reach 3001. The byte will reach 255 and then drop back to 0 and then repeat which causes an infinite loop. there is no problem with running that loop where you have it. Try using a word (2 bytes stuck together) instead of a byte. If what rbayer says is true then you will never be able to do a loop for that long anyways, but I don't think there is any harm in trying it.[/edit]
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 19-02-2003, 20:05
redbeard0531 redbeard0531 is offline
#0686 (Bovine Intervention)
redbeard0531 is an unknown quantity at this point
Send a message via AIM to redbeard0531
<edit>Removed stuff covered by people who replied faster that me.</edit>
Here is what I suggest.
GoSub Fire3:
Fire3:
count Var word 'Number of 26ms periods
Fire3On Var Bit ' 1 if the piston should fire
If p2_sw_trig = 1 then Fire3On = 1
If Fire3On = 0 Then DontFire:
If count < 3000 then
relay1_fwd = 1
count = count + 1 + delta_t
Else
relay1_fwd = 0
count = 0
Fire3On = 0
EndIf
DontFire:
Return
That is how I would do it, but it may not be exactly what you need.
Grease inside the Drill Motor gear box? archiver 2000 2 23-06-2002 23:07
