Go to Post I know the world needs more engineers, but FIRST isn't all about engineers and robots... that's why it's so great. - Ryan Dognaux [more]
Unread 19-02-2003, 21:57
John H. John H. is offline
John H. is an unknown quantity at this point
Drop Down System
Using a drop down system, we have experienced some problems. Someone on our team proposed asking questions on this forum, so, here I go.
Bear in mind that our robot does not meet the size restrictions. We have implemented a drop down system to fully use our robot.
1) We use two pistons to fall down. One seems to be falling at a different speed than the other. Our robot falls down on one corner, lifts its back high into the air and then drops fully. Consequently, our frame is being bent. How should we solve this problem and drop down smoothly?
2) Our two pistons are connected to a reverse L-shaped bracket/metal piece. This metal piece goes to the end of the size limit. Is there any suggestions for keeping this piece together and weight reducing?
3) Any suggestions for a suspension / any other suggestions?
Thanks a lot for your help.
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
