Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 21-02-2003, 20:21
Unsung FIRST Hero
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Swapping codes
I have codes for both the left and right side of the ramp. We want to load the code used in the pits and then somehow swap it before the match in case we are assigned sides and don't get to pick so we can swap codes. It's easy to merge the codes but how have other teams made it to swap sides? Are you using switches? Is there anyway to swap it on the RC itself without a switch? I'm just trying to find the simplest way and hopefully get out of installing a switch on the robot on the practice day. Thanks everyone.
Chopsaw? Chopsaw.
Alt codes in Forums? Elgin Clock CD Forum Support 2 27-09-2003 00:45
html codes Tim_Wochomurka Chit-Chat 2 01-11-2002 22:14
