Go to Post In FIRST you have the right to remain silent, anything you say can and will be held against you and your associates in the court of public opinion. - Koko Ed [more]
Unread 22-02-2003, 19:17
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: CD8 Unveiled at last
Unread 22-02-2003, 19:31
Tony's Avatar
Tony Tony is offline
#0111 (Wildstang)
Tony is an unknown quantity at this point
Send a message via AIM to Tony
Not at all what I was suspecting...
BEAUTIFUL nonetheless...as always...can't wait to see it in action...
Any elaboration//additional explanation?
::ADD::
That arm looks like it could kill someone, or do some SERIOUS damage
::ADD::
aTm
____________________________
i'm your zero
You are Neo
You display a perfect fusion of heroism and compassion.
Unread 22-02-2003, 19:36
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
nice....I assume that the arm can orient bins and stack them pretty well. Now hopefully wildstang is gonna hold their end of the deal and post something tonight.
Unread 22-02-2003, 19:37
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
It's true this year. Autonomous mode will most likely decide a match. If your auto code works and you can get up the ramp fast, you can control bins. It looks like 47's arm is meant to swing from the start box into the stack without having to go up the ramp. That's probably the fastest device at a competition. If it does swing from the start, then I have to wonder what else it does during the match.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 22-02-2003, 19:44
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
thats pretty cool if they can get about 4 or 5 stacks without moving in auto mode, but i was expecting a little more from them. something like what team 68 turned out to have this year to stop the match or something like what team 60 has to get every bin down and then hold them
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 22-02-2003, 20:28
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Time will tell...
...our machine is somewhat simplier than in past years. We will see if simplier is enough or simplier is too simple.
Bottom line, we fit in the box, made weight and we do pretty much everything we planned on doing.
Time will tell if we planned on doing enough or if we can work in new plans as needed.
Regardless of how the tournaments pan out, I am pretty proud of our team based on both effort and output.
Let the games begin...
Joe J.
Unread 22-02-2003, 20:31
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Did I miss 71's picture being posted? Raul's deal is "47 and 71 or no 111!"
An excellent machine as always, Team 47!
Unread 22-02-2003, 20:51
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Finally a CD robot that doesn't try to do everything! The more simple it is, the more reliable.
Just one question, does it have a swerve drive?
I can't wait to see this robot in action.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 22-02-2003, 21:01
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
Muwha it looks great! Maybe someone from their team wants to come and explain it... heh heh
Ahhh I wish I was sitting on the top of those bins
Unread 22-02-2003, 21:30
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Hehe... I bet I know what it does... but I won't tell. I will say I'm very interested to see CD8 in action. Your strategy looks very promising. It's one I thought up at kickoff, but didn't get to use. I can't wait to see you guys play!
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 22-02-2003, 23:53
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
seems that they will also be able to clear a scoring zone real easily, if they have omni wheels all they have to do is lay down the arm and drive sideways
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - ? : 573 Mech Warriors: Mentor
Try as I may, I can't stay away.
Unread 22-02-2003, 23:58
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
Just a problem with a robot like that at the SCRRF sectional. Our alliance partner had a robot like that, but while swinging in the crowd it narrowly missed the commentator and was disabled for the rest of the match. If an arm is extending that far, it could definately be considered a safety hazard.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 23-02-2003, 00:01
Roboticsrob
thats like rage in 2000 i believe, they hit a camera man in one of thier matches. correct me if i'm mistaken but i think thats what happened
Unread 23-02-2003, 00:07
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
Re: Time will tell...
Simplicity is the art and beauty of complexity.
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
  #15   Spotlight this post!
Unread 23-02-2003, 00:11
Scott Garver's Avatar
Scott Garver Scott Garver is offline
#0068 (Truck Town Thunder)
Scott Garver is an unknown quantity at this point
Send a message via AIM to Scott Garver
I don't think that Raul's deal will ever be met. 71 has never posted their robot in the past and I doubt they will this year. We don't even know if 71 knows we want them to because they have not responded in any way. Therefore if for some reason 111 would still be willing to post their pictures I am sure the rest of us would be appreciative.
By the way, like all other pervious CD bots CD8 looks great. Good job on following the best design advise ever, K.I.S.S
2000, 2001 - Truck Town Terror
2002, 2003 - Truck Town Thunder
2000 - Arm Design, Animation
2001 - Arm Design & Build - Pit Crew Captain
2002 - Chassis / Drive Train Design & Build - Assistant Team Captain
2003 - Chassis / Drive Train Design & Build, Arm Design - Team Captain
FYI 'Image Discuss:' is now 'Pic:' Brandon Martus Announcements 0 24-02-2003 12:17
